how to use tamiya panel line accent color
    March 2020
Posted by cervelo_mark on Tuesday, March 3, 2020 8:49 PM
Hi,
I am expermenting with weathering techniques on my aircraft and armour models.  But, I am having no luck using Tamiya's Panel Line Accent Colours.  How do you prepare the surface?  I prime my models and airbrush on flat tamiya acrylics for a top coat should I then spray on Future?  What do you remove the excess wash off with -- a cotton swab dipped in X20a thinner or something else?  Can you use the accent color directly over the top coat of flat acrylic paint then seal it under Future?
Help!
    January 2006
Posted by DiscoStu on Friday, March 6, 2020 9:43 AM
I've only used them a little bit, but they behave like a normal oil-based wash.  So make sure you have a good acrylic gloss coat on top of the paint, and then the excess can be removed with a Q-tip dampened with mineral spirits.
"Ahh the Luftwaffe. The Washington Generals of the History Channel" -Homer Simpson
    February 2016
Posted by lowfly on Friday, March 6, 2020 10:03 AM
DiscoStu
I agree but when it is said to "Dampen" the Q-tip....that means damp...BARELY wet.  Dip the Q-tip in the odorless mineral spirits and roll on a paper towel until it does not leave wetness behind. Anything more than that will ruin the acrylic finish.  I know from experiance.  :-D
    July 2018
Posted by Tickmagnet on Friday, March 6, 2020 10:08 AM
Youtube and paint mules are your best friends when it comes to trying new techniques.
