Stuart M3 Tank Tread
    October 2016
Posted by Mrchntmarine on Monday, March 30, 2020 3:52 PM
So plugging away on the Stuart and now id like to see if i can get some suggertions on how some of you all handle one pice treads.  These are rubber so do they need to be primed?  I using Tamiya Acryics.  Also, looking for suggestions on how the best way to proceed.... Questions -   Before install: Prime, spray treads then maybe tape treads and do outer teeth??  Brush all??  How to you guys do it?  Never done this before>. Tks!
Keep on modeling!
All the best,
William
    May 2011
Posted by Real G on Monday, March 30, 2020 4:45 PM
I painted my Tamiya M4 Sherman "rubber band" tracks with enamels for the basic colors, then used pastel washes to finish off.  I just snapped the tracks on when they were done.  I did get a little chipping, but you could touch up (or ignore them like I did).
“Ya ya ya, unicorn papoi!”
    October 2016
Posted by Mrchntmarine on Monday, March 30, 2020 5:10 PM
so mine calls for rubber and dark iron for the treads and spikes.  Did you tape or just free hand it?  I was going to try the different colors but wondering about how to mask it off or what?
Keep on modeling!
All the best,
William
    May 2011
Posted by Real G on Monday, March 30, 2020 6:04 PM
Nah, no worries - freehand it! I would suggest painting the rubber blocks first since they are the most exposed part.  Then do the end connectors and guide teeth.  Hide all wubbly marks with a dose of dirt/mud!  Keep it fun.
Posted by Don Stauffer on Tuesday, March 31, 2020 10:09 AM
Are you sure it is rubber and not vinyl?  In either case I have not had good luck painting either with enamel or any other paint.  What I do now with flexible tracks is weather with pastels.
For those using pastels, if you are not aware of jeweler's rouge look into it.  It is real rust- iron oxide, ground superfine.  It is used for polishing metals.  It is much cheaper than hobby pastels on a gram by gram basis, though you are likely to have to buy it in quantity, like a pint or so.  It applies like any other pastel.  I do have a hard time finding a very dark gray pastel, which is a color I like for base on treads.
    October 2016
Posted by Mrchntmarine on Tuesday, March 31, 2020 10:33 AM
Ok, got started.
Keep on modeling!
All the best,
William
    May 2011
Posted by Real G on Tuesday, March 31, 2020 11:43 AM
Tamiya “gluable” tracks are some kind of strene mixed with rubber or vinyl, kind of like Dragon’s DS tracks.  A friend reported long term cracking and splitting of Tamiya tracks and tires when enamels and oils were used.  He said to use only acrylics to paint and weather them.
My Sherman probably had the old polyethylene material that has been used forever.  It won’t hold paint well, but I found that pastels mixed with alcohol or Tamiya’s acrylic thinner holds on enough to withstand minimal handling.
    October 2016
Posted by Mrchntmarine on Tuesday, March 31, 2020 11:57 AM
Don Stauffer
So i thought somewhere i saw in the directions that they are rubber but now dont see it. Maybe i saw somewhere online in a description of the model. But the directions say can be painted with plastics paint....  And colors are called for.  They bend like rubber and look like rubber - i dunno.  Can a vinly material have those characteristics?  Anyhow I used Tamiya acrylics so we'll see i iguess.  I do expect some flaking or cracking - who knows.
Keep on modeling!
All the best,
William
