Panel line accent/wash
    April 2020
Posted by Foxy on Monday, June 22, 2020 8:33 PM
Firstly apologies for all the questions.. Started building my second model and want to get a bit braver and creative.. I want to add some some effects to a motorcycle engine.. So have looked into using panel line accent... However if things go wrong I could end up in trouble so have researched flory clay washes.. My question is are they the same thing or mores to the point will a clay wash do the same thing as panel line accent? As if need be the clay wash will clean off without to much heartbreak.. thanks in advance
    July 2018
Posted by Tickmagnet on Tuesday, June 23, 2020 6:47 AM
I use pastel washes. I hear the flory washes are great, just haven't broken down and bought any to try myself. Yes washes will create the same effect as panel liner only washes in my opinion are easier and faster to do. Both in application and clean up.
    April 2020
Posted by Foxy on Tuesday, June 23, 2020 7:03 AM
Tickmagnet
thank you for the reply... I was starting to think I'd asked a really dumb question lol... I've watched the tutorials on the flory washes and they seem to be completely idiot proof.. Which is what I need at this point in my model making.. I'll give them a whirl thank you again :)
Posted by Don Stauffer on Tuesday, June 23, 2020 8:51 AM
Any time I try a new technique I test it on a piece of scrap or discarded part or a sheet of plastic.  Then you can experiment to your heart's content.  No risk of damaging a good project.  For a lot of painting experiments, in this area everyone keeps a stock of those cheap plastic party spoons.
    July 2018
Posted by Tickmagnet on Tuesday, June 23, 2020 9:58 AM
Foxy
Tickmagnet
They look quite interesting. I went and looked and I also found some called UMP clay weathering washes that look the same as flory. Watched a video on the UMP washes and they guy sprayed them on as well as brushing them. Might just give them a try.
    February 2017
Posted by Tubosteve on Wednesday, June 24, 2020 4:33 PM
Foxy, Flory washes are great and, as you say, almost idiot proof. Just be sure to seal your paint before applying the wash else it will stain the paint..........don't ask how I found that out Embarrassed (my personal experience is with Tamiya acrylic). Just get everything sealed then slap it on and wait for it to dry, doesn't take too long.......and then wipe off with a slightly damp piece of kitchen roll and or cotton buds for the little fiddly places.........works a treat!
Stay safe........Steve
Currently on the bench: On the bench: Airfix 1:24 Spitfire Mk IXc (17001) as Silver Spitfire G-IRTY, Revell 1:48 Bristol Beaufighter TF.X (03943)
Finished 2024: Tamiya 1:24 Ford Mustang GT4 (24354)
Posted by Tojo72 on Wednesday, June 24, 2020 4:53 PM
Also use new brushes for the Flory,and don't contaminate them by using them for anything else.
    January 2020
Posted by wpwar11 on Wednesday, June 24, 2020 9:12 PM
Flory are great washes.  I build mostly 1/48 scale aircraft.  I found over a matte coat they leave a more dirty grimmy look.  Over a gloss coat it’s easier to wipe away and settle in panel lines or areas you want.
    April 2020
Posted by Foxy on Thursday, June 25, 2020 2:14 AM
Thanks for the replies guys.... Now have a full set of flory washes on order... Although with what I do I have no idea what I'm using most of them for.. I may have to  branch out into other areas of modelling :)
