Drilling Holes in PE Questions
    March 2015
Posted by JohnnyK on Tuesday, July 21, 2020 3:04 PM
I need to drill holes in PE. I am getting nowhere. I am using a drill bit in a pin vise and the bit just spins and spins on the PE. It's a new bit but it doesn't even scratch the surface of the PE.
    September 2012
Posted by GMorrison on Tuesday, July 21, 2020 3:33 PM
Do you have a punch set, like Waldron?
    April 2006
Posted by jgeratic on Tuesday, July 21, 2020 4:24 PM
A method I've used is replace the drill bit with a sewing needle or seamster pin.  Put your PE piece on a cutting mat, and then push the needle down.  It won't break through, but what you want is a slight deppresion on  the underside.  This you can sand off and a hole will appear,  or just repeat the procedure until you do.
Now you can systematicatily work through various drill bits until you arrive at the required hole size.
regards,
Jack
    October 2019
Posted by Tanker-Builder on Wednesday, July 22, 2020 9:57 AM
AhA!
 Ditto Jack's comment!
    May 2013
Posted by Greg on Wednesday, July 22, 2020 10:14 AM
One more Yes for Jack's method. I use a cheap machinist center punch knock-off, but the principal is the same. Create a small depression so the drill bit doesn't wander, and create geometry needed for the two cutting edges of the bit to bite into.
That said, you should be able to get away without it in a pinch. Drill bits need to be at least decent quality, and I suppose annealing the PE might not hurt, though I've never done it myself.
    March 2015
Posted by JohnnyK on Wednesday, July 22, 2020 1:32 PM
Jack,
I'll have to give that a try. Thanks!
John
Posted by Don Stauffer on Thursday, July 23, 2020 9:03 AM
Any time you drill a hole in metal, it helps to centerpunch.  That being said, most of the small drill sets I have bought are junk.  I am looking for a decent set (see other thread in this forum on drilling).
    October 2019
Posted by Tanker-Builder on Thursday, July 23, 2020 1:36 PM
Greg;
   The part about annealing the metal in your reply was very good advice. I just forgot about it. I do use it a lot, But, just like everything else, annealing can be carried to far as well. Once annealed the metal is easier to drill and form, But it also Remains softer!
    May 2013
Posted by Greg on Thursday, July 23, 2020 2:33 PM
Tanker-Builder
Thanks, TB. You forget to give advice about it, I forget to actually do it. Surprise
