Trouble applying Flory wash
    July 2019
Posted by Bobstamp on Thursday, August 13, 2020 12:27 PM
I am trying to use Flory washes to weather my Seahorse helicopter model, but the liquid just beads on level surfaces and runs down curved and vertical surfaces. I want to tone down one decal in particular, but the wash just beads on it, even after I sanded it lightly. I tried adding a drop or two of dish detergent to the wash, but that didn't work. Ideas?
Bob
Tags: Flory , wash , Weathering
On the bench: A diorama to illustrate the crash of a Beech T-34B Mentor which I survived in 1962 (I'm using Minicraft's 1/48 model of the Mentor), and a Pegasus model of the submarine Nautilus of 20,000 Leagues Under the Seas fame.
Posted by keavdog on Thursday, August 13, 2020 12:38 PM
You have to really shake up the wash to get the clay in suspension.  Are you washing over a clear coat?
Thanks,
John
Posted by Bish on Thursday, August 13, 2020 1:42 PM
What are you applying it to. It does react to some paints such as lacquer. And i have noticed with my extra colour enamels it will do that to some colours and not others.
Just keep running it over the area and after a while it will cover it.
    June 2014
Posted by BrandonK on Thursday, August 13, 2020 1:43 PM
Flory wash is just a powder or pastel in a water soap suspension. It is intended to go into surface details and panel lines. Using it to "tone" down a decal will end badly, trust me on this. Use the wash to highlight panel lines etc. Then when cleaned up you can flat coat the heli, then use pastel chalk on a paint brush to "dull down or dirty up" that decal. This will work like you are wanting, the flory wash will ruin the decal and you won't be able to fix it.
BK
On the bench:
A lot !! And I mean A LOT!!
                         14 / 5 / 2
                              Tongue Tied
    July 2013
Posted by modelmaker66 on Thursday, August 13, 2020 3:47 PM
BrandonK
BK
Ditto
    July 2019
Posted by Bobstamp on Thursday, August 13, 2020 5:22 PM
keavdog
I did shake the bottle of Flory weathering solution, but perhaps not enough. I’ll try that.
The helicopter has been sprayed with a clear gloss spray, but IIRC the Flory web site says that their washes can be applied over any type of surface from matte through semi-matte/semi-glossy to glossy. That hasn’t been my experience, not so far.
Bob
    July 2019
Posted by Bobstamp on Thursday, August 13, 2020 5:26 PM
BrandonK
The decal that I sanded lightly to see if it would take the wash better certainly didn’t thrive — bits of it actually came off. But that’s OK. BF — Before Flory — it looked like it was factory-fresh and not at all what you would expect to see on a weathered, combat-weary helicopter near the end of its effective life, in Vietnam in 1966. But even with my deliberate “mistreatment” of the decal, most of its white portions still look factory-fresh and unrealistic.
I’ve looked at some videos about applying Flory washes. The ones I've seen show large surfaces of the models, not just panel lines and other recessed details, being covered with the wash. When the wash has dried, it's been selectively wiped away to achieve an overall appearance of weathering and hard use. That’s the level of “detail” I’d like to achieve,
Bob
    January 2020
Posted by wpwar11 on Thursday, August 13, 2020 6:13 PM
Try it over a flat surface.  I had a similar experience on a gloss surface.  It stays in panel lines and allows me to keep more on in areas I want to show more dirt and grim.  I use the gray and dirt one the most.
    November 2008
Posted by plasticjunkie on Thursday, August 13, 2020 8:02 PM
If you want to tone down something then use a filter over a flat finish and not gloss cause it will not be properly absorved by the surface and it will bead up. Over gloss Flory will settle into sharp details like bolts, grills etc, and settle into recessed details like panel lines. The best way to tone down decals is to either use a thinned down enamel or oil wash or dot style filter for tonal effects.
Also Flory will easily get contaminated by using a non dedicated brush. I use Q Tips and then toss them in the trash. When contaminated it will do weird things.
Here is an example of what I described. I used a combo of a dot oil paint filter then shot clear acrylic flat  to seal it. Next day I used a grimy dusty filter oil wash over the flat finish to tone down the bright white number outlines.
 GIFMaker.org_jy_Ayj_O
    January 2020
Posted by wpwar11 on Thursday, August 13, 2020 9:15 PM
Plastic makes an excellent point about contamination.  I use new brushes labeled Flory that only get used for that particular wash.
    July 2019
Posted by Bobstamp on Friday, August 14, 2020 12:15 PM
plasticjunkie
Unfortunately, I don't use an airbrush. It would be almost impossible in my small apartment. So, I have to rely on brushes (and I will use Flory-dedicated brushes in future).
I think that I am making some weathering progress on my Seahorse helicopter. More of the brushed-on Flory washed stayed on the model than I realized. I used a combination of Q-Tips, an old toothbrush, and tissue paper to soften the effect, and then applied heavy black Flory wash to panel lines and sharp details. Hope it works!
If I destroy the model, which seems unlikely with the Flory washes, well, I've got two more of the same kits to try. Lord knows I couldn't screw up a second kit more than I've screwed up the first one. I've only broken a rotor blade, both main landing gears, accidentally sanded away some important panel lines, managed to install the flight deck at an unfixable and incorrect angle (it slopes to the right and I have no idea why), spilled a glob of lacquer on the tail, obliterating a panel line, and utterly failed at installing some PE; I need the eyes of an eagle just to see some of those parts, much less install them. Nevertheless, from a little distance it looks darned good, to my eyes anyway. I'll upload some pictures, eventually. If I don't completely wreck it in the meantime!
Bob
    January 2020
Posted by wpwar11 on Friday, August 14, 2020 5:01 PM
Hey Bob do you use an optivisor or any kind of magnifying product?  My modeling game significantly got better when those small parts got 3.5 times bigger.
    July 2019
Posted by Bobstamp on Friday, August 14, 2020 5:09 PM
wpwar11
Just last week I received the Carson optivisor that I ordered. I've used it just once, but it worked well. It has a LED lamp and comes with lenses in 1.5X-, 2X-, 2.5X- and 3X-magnification. The 3X is almost too powerful. I've also received a wax pencil designed for making jewellry; haven't used it yet, but I think it will be very useful. I've given up using tweezers to hold small parts, because they are likely to launch said parts into orbit.
Bob
    January 2020
Posted by wpwar11 on Friday, August 14, 2020 5:26 PM
The visor and wax pencil are great tools.  You’re right about the 3x power.  You have to get real close to view the part.  I still find it better than without.
Good luck and happy modeling
