- Member since
Posted by berny13
on Friday, March 28, 2003 10:09 PM
You can use an airbrush or spray can. Mask any clear parts such as canopy, windows, or lights prior to spraying on the dullcoat. If you don't it will frost the clear and nothing can be done to correct it.
Any type of flat coat can be sprayed over Future once it has cured. Do it in light coats, adding more after the first coat has dried, if needed.
Berny
Phormer Phantom Phixer ![](http://i22.photobucket.com/albums/b309/berny13/f102copy.jpg)
On the bench
TF-102A Delta Dagger, 32nd FIS, 54-1370, 1/48 scale. Monogram Pro Modeler with C&H conversion.
Tamiya F-4D Phantom II, 13th TFS, 66-8711, 1/32 scale. F-4 Phantom Group Build.
