My Panel Line Experiment
Posted by Anonymous on Friday, April 16, 2004 3:07 AM
So I tried several techniques of highlighting 1/72 panel lines, using an old Dragon Wings diecast as my testbed. Here are the results.
Mechanical pencil:
This worked okay; I tried "writing" on the panel lines as well as sanding the lead and brushing the dust in. Not permanent (i.e. need to seal it), but it's alright. The downside is you get kind of a sheen from the graphite when tilting the model towards the light.
Wash:
Disaster, but I don't think I did it right. I used Tamiya paint, thinned with warm water and drops of detergent and vinegar. The pigment totally separated from the liquid and settled at the bottom of my jar. So I tried an enamel wash, Testors thinned with airbrush thinner, which worked better. Still, I was never a big fan of washes; it just seems too messy to "sludge" it, and I can never get the look right when using capillary action.
Dry Erase Marker:
By far, I got the best results with this one. If anyone has the last FSM with canopy masking on the cover, check the pics of the 1/72 Hasegawa Super Hornet for what my results looked like. I just "marked" anything I wanted detailed (panel lines, rivets, drains, etc.) and wiped away the excess. Here's the trick, though: dry wiping may have worked on a glossy surface, but it didn't on the flat diecast. I tried a cloth soaked with nail polish remover (which wiped away the paint!), Windex (which oddly didn't work), alcohol (which worked but will pick up paint if you scrub hard), and a dish soap and water mixture (which worked perfectly). The results are a little stark (i.e. high contrast), so try it on something first to see if the look suits you. I love it, but YMMV.
The main reason I'm posting this is because many people posted *ideas* on this and other boards, but not so many *results*. Comments welcome!
- A1C "Flip" Wilson, USAF
- Aviano AB, Italy
Posted by Archer1 on Monday, April 19, 2004 2:51 PM
Flip -
I've used #'s 1 and 2 with pretty good results. For the pencil routine, I just ise a sharp #2 pencil and draw through recessed panel lines. I usually do this after the color coats. The pencil line work best (for me anyway) on flat paints. Since the AC with get at least a gloss over coat, sealing isn't a real problem. That also get rid of most of the shinniness. As for the wash, that works pretty well too, but, I use a mixture or acrylic paint, water and a touch of dish washing liquid. Here, I put the "wash" on after the gloss coat, and decalling, as it will be easier to wipe off the excess from a gloss finish. Once I'm happy with the effect, I'll finish weathering, if necessary, and shoot the flat / semi gloss coat.
Haven't tired the dry marker trick yet, seems like more work than the other two though. As you said, YMMV.
Archer out.
