Similar to Striker I sometimes use a short piece of soft wire, two per door.
Cut a short piece and glue it to the inside of the door at points where there are raised ribs if any. That'd probably be where the hinges are. Then paint to match inside of door.
When dry, bend hook in protruding ends and get it to hook inside of edge of well. Put a drop of CA at each point where it attaches inside. Hold till dry. bend a little until it looks right.
An advantage is that if you bump it it will bend but not break off and can be straightened.
Bill
