M1000 black tubing issue
    February 2015
Posted by wadams on Wednesday, August 24, 2022 10:07 AM
Does anyone have problems with gluing the black airline tubing for the M1000 HET Trailer?
Tubing used to NOT have wire in it. I have removed the wire on some to try it that way, but CA gluing is not holding. In addition to that the spots to glue it onto are larger than the tubing I.D..
I haven't had this problem on other model as the tubing is the correct type for them.
Does anyone have any ideas on this??
Warren Adams
    October 2019
Posted by Tanker-Builder on Wednesday, August 24, 2022 4:35 PM
I don't use it.
     I cut off the anchor point, Drill a hole the right size and use fine electrical wire in black, I also fasten it with with BONDIC cause it holds better! when you put a wee bit in the hole, insert the wire, and the little ring of glue will set up locking the piece in place.
    February 2015
Posted by wadams on Wednesday, August 24, 2022 7:21 PM
Hi Tank-Builder
Would Bondic be the one that uses UV to cure it?
Warren Adams
    October 2019
Posted by Tanker-Builder on Thursday, August 25, 2022 9:22 AM
Hi Warren!
 Yes, that would be the one. When I explained it I hope it made sense to you! When you insert a part in a hole to accomodate it, a nice litle ring squeezes out around the piece. Hit it with the U.V. and it works just like a Retainer ring on a real wheel outside axle fitting.
