What skills do I need to learn next? (Automotive models)
    April 2023
Posted by ctruss53 on Thursday, July 27, 2023 2:32 PM
Hey everyone.
I build automotive scale models nearly exclusively. And I try to learn something new with each and every build.
In late 2021 I learned complex lowrider paintwork. last year I learned how to weather a rally car. And this year I am learning how to scratch build stuff and customize model kits.
Then later this year I am going to learn how to add transkits to my builds.
What are some key skills I should learn now that I am customizing and scratch building things?
Insert wise quote here.
-Chad
    January 2020
Posted by wpwar11 on Thursday, July 27, 2023 5:16 PM
If your not already doing it learn how to wire an engine.  Drilling the holes, using various methods for clamps, using lead wire, using braided hose, and vinyl tube.  I'm still learning myself but it makes for a much more authentic car model.
Posted by keavdog on Thursday, July 27, 2023 6:30 PM
And the heater hoses and battery wiring.  I've yet to have success with braided lines, tried once but the braid wicked up the super glue.  I've also done brake cables and fuel lines a couple times before - under the car.
Thanks,
John
fox
    January 2007
Posted by fox on Thursday, July 27, 2023 8:31 PM
Just have a quickie suggestion. Whenever you see electronics being thrown away, salvage scraps of the different sizes of wire in them. Any type of model can can use a piece of wire for different reasons. I have a shoe box that is full of any size that I have needed over the last oooooooh 50 years. With all the people using lights in their models, it really comes in handy. Saves a little bit of 2 cents too. Those rolls of wire are getting a little expensive lately.
Hope that this helps.
Stay Safe.
Jim Captain
 Main WIP:
    January 2020
Posted by wpwar11 on Friday, July 28, 2023 6:07 AM
keavdog
Those braided lines are tough.  My problem is the ends get to frayed and the connection points don't look right.
    April 2023
Posted by ctruss53 on Friday, July 28, 2023 2:16 PM
Thanks for the input.  I do wire engines.
I was trying to gear this more towards skills used in my latest adventure of scratch building and modifying.
Some examples:
Creating panel lines where there are none.
Body fillers and shaping techniques.
And another big one for me is how to trick my brain into seeing simple shapes in things when trying to scratch build complex things.
I am also learning door hinges, but I am really struggling with the details. Like adding thickness to the door so the interior panel fits right when the door is closed.
-Chad
    October 2019
Posted by Tanker-Builder on Monday, July 31, 2023 8:43 AM
The Door!
    An interesting and complex yet simple part of every model car. The hard part is yes, making the gap solid. I do it simple.I drop the interior into the body and tape it at the windowsills. Then I measure the distance between the bottom and the body.
      NO WAY!! After I have installed temporarily, the interior WITH the interior and exterior, of the door already separated. I then put a strip of paper in there wide enough to fill the gap.Then carefully draw the inside of the gap on the strip.
     That then is my pattern for cutting supports away from the jambs. Remember the jambs are different from outer edge to inner panel. Go to your car and take a photo of the area and you will figure out exactly what I am saying,
     Oh I forgot the most Important one. PATIENCE !! No one modeler I know of became a trophy Winner overnight. Sometimes weeks, months, or even years were required. Why? in each, the biggest thing was the measure of patience the person had! Be patient with yourself and if a part or assembly stumps you, go drink a soda , cup of Coffee or just take a breath, It'll come to you!
    April 2023
Posted by ctruss53 on Tuesday, August 15, 2023 10:46 AM
Great information.  Thank you.
-Chad
    October 2019
Posted by Tanker-Builder on Monday, August 21, 2023 1:43 PM
Aha!
      Here's some more info. If you want your doors to fit right Don't make your hinges as duplicates of the stock hinges. It is possible, but, then you will have door weight issues!
    March 2022
Posted by missileman2000 on Tuesday, August 22, 2023 9:40 AM
keavdog
I found a neat thread from Micheals, It is a heavt gauge aluminized thread, and is twist is pretty high so they look reasonably like corrogations. It glues well with gel CA.
