- Member since
April 2010
Posted by Mustang8376
on Tuesday, October 3, 2023 7:38 AM
Thank you everyone for the answers. It is all very much appreciated and Tank-Builder you didn't miss part of the question. After your first response I edited the question to note that the fuselage is joined and there is no way to get to the back of the hole. Important information to have that I forgot to share, so that is on me.
As it stands, I was able to get the hole plugged using putty, since th edges were beveled on some sides (not a straight hole). I will be letting it dry for about a week and see how it sands. Now that being said, if the patch doesn't work, I will definitely be using the drywall fix method. If nothing else, this is just a lesson learned and a chance to lean some new skills in case it comes up again!
Current build: 1/32 Hasegawa F6F-5
Completed: 1/48 Hasegawa F-16C, 1/48 Revell Mig-21PFM, 1/48 Revell/Monogram AH-64A, Revell/Monogram 1/48 F-14D, AMT 1/420 USS Defiant, AMT 1/650(?) USS Enterprise, 1/72 Bandai VF-1J, AMT 1/537 USS Reliant, Academy 1/35 M1-A1 Abrams, Academy 1/48 F-86F30, Linbergh's USS Gato
