I need rust
    July 2003
I need rust
Posted by zokissima on Wednesday, April 28, 2004 8:20 AM
Hi all
Not too long ago, someone posted instructions (well, a link TO instructions Smile [:)] ) describing how to create actual rust out of a steel sponge or something like that.
I've lost the link, but now need to know how this is done. I will be painting some tracks soon, and would like to try this out.
Also, if anyone has suggestions for ACRYLIC rust colours, perhaps Tamiya, it'd be very much appreciated as well.
Thanks Big Smile [:D]
Posted by Anonymous on Wednesday, April 28, 2004 9:25 AM
Ok try this go to your local chemist / toy store and ask for some iron filings, sprinkle or glue onto painted kit with a rubber glue leave in the rain or moisten said filings, viola rust stains on your paint, this is not a wind up it works ,a bit fiddly but it does work.
I tried it on some large scale kits a few years ago and it came out great, lord I have just remembered this from onks ago thanks for getting the grey matter functioning again zokissimaApprove [^]Smile [:)]
Posted by Archer1 on Thursday, April 29, 2004 11:02 AM
z.
I've had pretty good luck with the Model Master Acryls "Rust" paint. Depending on the effect I'm looking for, a silver or black dry brush over it gives the right accents.
Archer out.
Posted by Anonymous on Thursday, April 29, 2004 2:50 PM
I vaguely remember the thread, and I didn't bookmark it.Sigh [sigh] If I remember right and this is the one you're talking about;-You take some ordinary steel wool. Let it sit in a plastic container in a very small amount of water (just enough to allow for a short evaporation process) and let the the steel wool rust. When the water has evaporated you shake the rust out of the wool for use. Or maybe you spray the wool or dip the entire piece first. I haven't tried this method personally and I'm not even sure if it's correct. Does it sound right to you? I hope it helps. -Cheers
Posted by Anonymous on Friday, April 30, 2004 12:03 PM
When the wool dries, it will become brittle and crumble. I could see you grinding this into the paint coat somehow or adhere with white glue maybe.
I've never tried it but I have seen steel rust at the kitchen sink and this seems
one of the most plausible routes to go!!!! Wink [;)]
Good luck!!!! Smile [:)]Big Smile [:D]Cool [8D]
Posted by maddafinga on Friday, April 30, 2004 5:56 PM
It seems like the guy put a hunk of steel wool into a small jar, like a babyfood jar maybe, and filled it with water (and some vinegar I'm thinking?). When the water had evaporated, he took a stick and ground the wool up and repeated again until it was a fine fine powder. That was how it worked to the best of my recollection.
Madda Trifles make perfection, but perfection is no trifle. -- Leonardo Da Vinci Tact is for those who lack the wit for sarcasm.--maddafinga
Posted by Anonymous on Saturday, May 1, 2004 9:47 AM
Yeah, I think that's it. I don't remember the vinegar though.But hey, why not? Smile [:)]
Posted by Anonymous on Sunday, May 2, 2004 10:20 AM
I actually do something extremely different. The materials I use for rust is flour, white glue and the paint. I build the model and before painting I coat the rusted areas with white glue and pour the flour on it. I let it dry and then I paint it with Tam acrl red-brown or Mod Master's acryl rust. I try to stay away from the mod master's stuff because it looks too redish and it should be a little more orangish. I think it looks good, but if you want rust streaks, use tam red-brown. You need an AB, or I guess you could do it with heavly thinned red-brown on a brush, but never tried it. Just load it in and dilute it down a lot and just make the streaks on the model. I think it looks good, gotta get some pics up of it...
Posted by djrost_2000 on Wednesday, May 5, 2004 12:47 AM
You could also try the Rustall system which can be found in the Micromark catalog. http://www.micromark.com
It comes with 4 bottles including liquid and powder and produces real rust.
-Dave
    July 2003
Posted by zokissima on Wednesday, May 5, 2004 8:41 AM
Madda, yep that's the one. I wanted to check it because I assumed that you'd need alittle bit of vinegar or lemon juice or something like that, because the corrosive properties would make the steel rust very quickly.
