graphite sticks
graphite sticks
Posted by Anonymous on Thursday, April 29, 2004 1:37 PM
I just bought some graphite sticks so I can weather a model tonight. I plan on scraping some flecks off, the rubbing it on the plane and protecting it with future floor wax. Is this a good way to go, or does anyone have a better way of doing it? I am not ready to try the oil based wash yet.
I should clarify that I am not trying to make it look like it just took a mud bath, just some simple weathering showing panel lines and various stains.
Thanks.
    January 2003
Posted by shermanfreak on Thursday, April 29, 2004 2:43 PM
I never clear coat after I put the pastels on. Never liked the effect and also reduced them visually. After the pastels are on, the kit becomes hands off territory.
Posted by Anonymous on Thursday, April 29, 2004 3:13 PM
O.K.
To make sure I understand this correctly, If I were to do an oil wash, accoding to swanny's website: (to be more hands on and permanent)
Start after a future base coat
I get an oil based paint (will acrylic work?). dilute it to the point it is the consistancy of coffee.
"wash" the plane with the mixture (is that like dipping a towel into it and then rubbing down the plane)
After about 5 minutes, wipe off any excess.
Apply future top coat
    March 2004
Posted by SeaBee on Friday, April 30, 2004 9:17 AM
To be honest, I don't think acrylics will work over future. I strongly suspect it is water-based as well. Thus, the solvents might damage your future coat. I also work with acrylics mostly. What I do, is to spray a clear enamel or Tamiya's clear spray (X13, I think). That does not get affected.
The wash: you made the thin wash. Now just take a brush and you can either brush it on where you want it, or let it syphon into panel lines by just dropping in a little. Either way, you end up with a rank mess. I then wipe a cloth/earbud with a little bit of thinning agent (for acrylics that's either Tamiya acrylic thinners, Windex, or whatever your preference is) over this "mess". You should end up with a cleaned up model, with your recessed darkened.
Best is - try on a scratch piece to get what you're comfortable with.
Good luck & enjoy!
Posted by Archer1 on Friday, April 30, 2004 10:04 AM
CState -
I use Pastel (chalk) powder. Spray color coat, let dry. Do panel lines, chalk dust. Spray clear. Decal. Add more dust, if necessary. Spray light coat of dull or semi-gloss.
One note, spraying over the dust can lighten it, so you generally have to use more than you'd initially think!
Archer out.
Posted by Anonymous on Friday, April 30, 2004 11:55 AM
thanks for your input guys.
