M2 Smoke Discharger?
Posted by Anonymous on Monday, May 3, 2004 8:13 PM
Howdy Folks!
I posted a similar post in the Armor section recently and I got plenty of help, but I still have many questions. Too many to post probably. lol
Anyway, I just got promoted to Aftermarket, but as stated in a previous forum I read today, Murphy paid a visit to me also, last week. lol So it's time to get some Scratchbuilding/Kitbashing experience. What I need to do is, I need to build some smoke grenade launchers for the Tamiya Bradley M2. I've bought some 1/16" brass tubing, and a larger size (in case I decide to have them loaded and with caps on them)( or else maybe I could use Putty, or a comboConfused [%-)]) I actually think they might look good empty, I don't know, and I also have the correct gauge styrene to shape the bases out of. I have never seen grenade launchers in person, at least since I was a kid on a visit to the British War Museum, so any help is greatly appreciated!
That's the kind of feedback I'm looking for this time - What you guys would do? (loaded; unloaded, etc.) and which routes you would take in building them? (shaping styrene, cutting tubing, etc.) I have some pics that are very helpful, but the more pics the better, in my opinion, especially close-ups or personal knowledge, which is even best sometimes. Cheers, -SpencerSmile [:)]
    January 2004
Posted by MusicCity on Wednesday, May 5, 2004 7:48 PM
Spencer, either styrene or brass would look fine if they are built to the proper scale and appearance. I've seen pix of grenade launchers mounted on armor, but never relly looked at them. The hard part is going to be getting the wall thickness of the tube to look right.
I haven't had real good luck getting regular model paints to stick to brass and usually prime it with some primer like Krylon that will adhere to metal better. Styrene might be easier to paint. Styrene would also be easier to sand down if you need to cut down on the diameter.
Posted by Anonymous on Wednesday, May 5, 2004 9:01 PM
Thanks Scott, I've used Kryon primer on this build already, so all I should have to do is mask a bit and touch-up the rebiult parts. I lost the mandrel the other day that's used with the Dremel cutting discs (Murphy Returns!) and was finally able to pick one up last night. I did try other Dremel bits, but didn't have much luck. As you stated before, it melts pretty easily. I hope the emory discs work better on the styrene, if not, I might try just scribing and snapping, then sanding to shape. I'm taking the night off tonight from modeling. (at least from anything that could be detrimental to the build) I had a rough day at work and I think the fatigue would lead to mistakes. Cheers, -Spencer
