New Seam Filler - great stuff!!!
    January 2003
Posted by Jeff Herne on Wednesday, May 5, 2004 2:15 PM
A friend told me about this stuff they use to fill cracks and chips in porcelain called Porc-a-Filler (stupid sounding if you ask me)...I got a bottle a Home Depot, and it's great stuff...cheap (about $4) and I've NEVER used anything that sands cleaner and smoother...
Great stuff, give it a try...
(I'm in NO way affiliated with the product or company)...
Jeff
    December 2003
Posted by thevinman on Wednesday, May 5, 2004 2:34 PM
Thanks for the tip!
Posted by rjkplasticmod on Wednesday, May 5, 2004 3:11 PM
Jeff, since it's apparently designed to fill cracked porcelain, how well does it adhere to styrene? If it doesn't chip out easily, then it may be worth a try.
Posted by Woody on Wednesday, May 5, 2004 7:42 PM
Sounds very interesting! Is it a two part product? How thick is it?
" I wish to have no connection with any ship that does not sail fast; for I intend to go in harm's way." --John Paul Jones
    January 2003
Posted by Jeff Herne on Wednesday, May 5, 2004 11:39 PM
Rick,
I've yet to have it chip or flake off...it's a solvent based filler, so I think it actually bonds to the styrene...although the stuff dries really fast (3-4 minutes), it does soften the plastic underneath a bit...but within 10-15 minutes you can sand it without any adverse effects.
It's not a heavy filler like Squadron putty, its got the consistency of melted ice cream... I've been using an old airbrush needle to apply it with good results...it sure beats the old way, glopping in putty with a spatula. Oh, btw, it's a one part filler, so no mixing or anything.
The best part for me so far, is that it hasn't shrunk at all...my Spitfire XIV, which I completed in March, is already showing signs of shrinkage (used Tamiya putty). I've used it on some 1/144 stuff (B-58, Fw-190, Ki-44) and some 1/72 armor, and so far so good...no shrinkage.
Jeff
Posted by rjkplasticmod on Thursday, May 6, 2004 4:06 PM
Jeff, thanks for the feedback. I'll try & find it on my next stop at Home Depot.
Posted by maddafinga on Thursday, May 6, 2004 6:27 PM
no kidding, I'm always on the lookout for a really good filler. I have a perfect use in mind for it. There are massive gaps in an old tie fighter model I have.
Madda Trifles make perfection, but perfection is no trifle. -- Leonardo Da Vinci Tact is for those who lack the wit for sarcasm.--maddafinga
Posted by Anonymous on Friday, May 7, 2004 1:18 AM
Okay Jeff, you got me!!! I have to go across the street to Home Depot for some new light bulbs, so I'm gonna pick some up then....Thanks for the tip, as I can never get enough fillers as they all seem to not work for me!!! LOL
Posted by Anonymous on Friday, May 7, 2004 1:36 AM
Jeff did you recommend the Glad Press N Seal also??!! LOL Not too many people were diggin that one!! LOL I actually bought it, but haven't had the opportunity (read guts) to try it out!!
    January 2003
Posted by stinger on Friday, May 7, 2004 7:55 AM
Thanks for the tip, Jeff. I'll give it a try.
stinger
May an Angel be your wingman, and the Sun be always at your six
    January 2003
Posted by Jeff Herne on Saturday, May 15, 2004 10:28 AM
Hey Kik,
Yea, I recommended the Press N Seal, and I'm still using it with no adverse effects...go figure...
You can't please everyone.
Jeff
    May 2003
Posted by qmiester on Saturday, May 15, 2004 5:29 PM
Jeff
Is there any kind of a thinner listed (acetone, laquer thinner etc) mentioned on the box or in the instructions? If there is, is the porc-a-seal thin enough to apply with a brush? Guess where I'm going.
Thanks
Quincy
    January 2003
Posted by Jeff Herne on Sunday, May 16, 2004 4:28 PM
There's nothing on the bottle, and I tossed the box, but I can tell you it sure has a thinner-type odor to it...it also softens the plastic, so I would guess that its a toulene based carrier.
Jeff
Posted by Anonymous on Sunday, May 16, 2004 5:10 PM
LOL, I hear ya Jeff....I was only jabbin' ya!!! I just haven't had a particular need for the press n seal just yet, though I am getting close!!!
    May 2004
Posted by KINGTHAD on Monday, May 17, 2004 12:29 PM
How well does the putty take to paint??
James
    May 2003
Posted by styrene on Tuesday, May 18, 2004 7:10 AM
This stuff appears to be similar to lacquer-based products. It contains both n-butyl and isopropyl alcohol, as well as acetone, xylene, and toluene (small percentage). For the filler portion it uses aluminum oxide, and barium sulfate. It looks as though lacquer thinners may be used to thin this product. What's interesting is that this product appears to be almost identical to the lacquer-based automotive putties many of us modelers have been using for years (DuPont, 3M, etc.). Because of the similarities, there should be no problems with priming and painting.
Gip Winecoff
Posted by rjkplasticmod on Thursday, May 27, 2004 3:32 PM
Hey Jeff, I bought a bottle and tried it out. It is indeed great stuff. I had an old build that I'd started and then shelved because of some nasty gaps ( part my fault, part lousy kit ) that I didn't want to fill with my usual CA. Figured nothing to lose so tried the Porc-A-Filler. Applied it with a round toothpick, let it set overnight, filed, sanded, polished and it came out flush & smooth. Primed it 2 days ago & no sign of shrinkage yet. I'm going to let it set for a while before I paint, just to see if any shrinkage occurs. You should submit this as a readers tip to FSM.
Posted by Anonymous on Thursday, June 3, 2004 1:37 AM
Jeff
How does it take to wide gaps, you know the really nasty ones you look for a tree trunk to fill with??
-Jeff
Posted by Anonymous on Thursday, June 3, 2004 7:55 AM
Went to Home Depot and they said they didnt sell this? I see it online but was hoping to find it locally. Will look in lowes today.
Posted by Anonymous on Thursday, June 10, 2004 1:39 PM
Funny that xylene and cellulose was mentioned...these kill plastic in no time....
however a friend of mine uses a custom made putty of baby powder soaked in cellulose and apparently it cancells out the ill effects while producing a nice and shrinkage free finish....Did I try it...no////
Do I trust him....well If I am to believe him he drove a Yugo at 200kmh, 120 miles per hours that is on two wheels during a police chase....People in Europe know what the Yugo cars look like .....lets say is a Eastern European Mini....lol
Posted by Anonymous on Thursday, June 10, 2004 3:29 PM
Where can I buy Glad Press N Seal? I'm near Colorado Springs. I'm at : anjyn@msn.com. Please reply to that email address.
Posted by Anonymous on Thursday, June 10, 2004 3:42 PM
So far I see no one has reported any shrinkage problems. Wouldn't really exspect any if you think about it. Wouldn't work very well for it's intended purpose if it was subject to shrinkage
Posted by Anonymous on Friday, June 11, 2004 9:45 AM
Ok, folks, now for the REALLY important question.........
What is the equivalent in the UK???
Posted by Anonymous on Saturday, June 12, 2004 6:35 PM
I work at Home Depot and I am always on the lookout for new products to try on models. I have been using Porc-a-Filler for about three years with great results. No mixing, easy to use and it drys quickly. Great stuff!1
Posted by Anonymous on Saturday, June 12, 2004 6:37 PM
Oh yeah...Porc-a-Filler is found in the Kitchen and Bath department as well as in the Paint department, usualy on a side-cap.
Posted by Anonymous on Monday, June 14, 2004 8:02 AM
Well, here in Brazil we use a substitute for putty usining epoxi resin, that comes in two parts. We call it DUREPOXI , and has two different compounds, one gray and one white.
At first, we mix the two parts, until them become one light gray paste. And now comes the "secret weapon". A cream for skin called Nivea. Mix a little part of cream into the paste and see the effect : A very easy handle putty, that is easy to aplly and sanding too.
That is my trick for alternative putty.
Clayton Maximo
Brasilia - Brazil :-)
