Artists use a sprayable "workable fixative" to seal chalk or pastel dust, pencil, charcol, etc. Workable in that it can be gone over again if neccessary so you can build up layers. In some cases even erasing it.
It retains its flat nature (but does darken a little) because it is sprayed on paper, which absorbs much of the excess. Unlike a painted or plastic finish which has no absorbtion qualities, so the excess sits on its surface and dries. Leaving a little satin or gloss sheen.
An article in one of the mags (maybe even FSM) mentioned using acetone to use as a binding agent. This creates its own problems in that it will
a) evaporate quickly
b) acetone is pretty noxious stuff and will debond your joints as well as melt your plastic if there isn't enough paint on it.
c) may react with your paint.
I think others put it best. Don't do anything to it. How often do you handle your models that would require a "touch up" ? Even if you traveled them from show to show a presentation or display base will keep you from touching the model and thus prevent putting undue stress on your finish.
"Imagination is the dye that colors our lives"
Marcus Aurellius
A good friend will come and bail you out of jail...but, a true friend will be sitting next to you saying, "Damn...that was fun!"
