Rolling PE parts?
    July 2003
Rolling PE parts?
Posted by KJ200 on Monday, May 10, 2004 7:24 AM
I need to put a gentle curve in some PE parts, but wonder should I aneal them first?
Any ideas?
Karl
Posted by Anonymous on Monday, May 10, 2004 7:32 AM
Might make them warp or brittle I use a size 12 knitting needle Kaths given up what bit are you attempting to bend?
    January 2003
Posted by shermanfreak on Monday, May 10, 2004 9:07 AM
I've always used a piece of wood doweling to get my PE to curve.
I've never anealed them before doing this and have had no problems.
Posted by Anonymous on Monday, May 10, 2004 9:38 AM
rolling PE? Mine just flies.
    July 2003
Posted by KJ200 on Monday, May 10, 2004 9:41 AM
Thanks guys.
What I'm trying to bend are the interior panels of a 1/72 Fw190's landing flaps. So the whole this is only about 30mm long, by about 8mm.
It just needs a slight curve, and I'd read that anealing was supposed to make metal less springy, and therefore easier to bend.
Think I'll just go with a length of thin dowl on a soft mat.
Thanks
Karl
    July 2003
Posted by KJ200 on Monday, May 10, 2004 9:45 AM
Micheal, I know that feeling.
I've lost far too many of Eduard's fine creations to the floor.
At least in my case it's a nice flat laminate floor, and I'm well practised with the torch hunting technique!!!!!
Karl
Posted by Anonymous on Monday, May 10, 2004 5:53 PM
I don't think that you should aneal the PE part since they are thin enough to bend easily. I use the round end of my file which is about 4mm to roll the PE part. I do it on the cutting mat which is a bit soft & makes rolling the part to it's desired size easier. I've done this on the PE exhaust pipe guard of the Italeri LAV-25 & it worked just great. Big Smile [:D]
