Dry transfer
Dry transfer
Posted by Anonymous on Sunday, May 16, 2004 1:42 AM
Hi. I have a dry transfer sheet. My problem is when i peel off the thick sheet where the decal is supposed to be attached the decal has already adhered to the other side. is there any solution to my problem other than buying another kit?
Posted by djmodels1999 on Wednesday, May 19, 2004 2:44 AM
I'd like to help, but I'm not certain I understand what your problem is...
Posted by pingtang on Friday, May 21, 2004 9:54 AM
with all the dry transfer sheets i've used the decal is supposed to stick to the thin sheet. The thick sheet is just a backing. You'll probably notice one side of the thin sheet with thetransfer attached is slightly sticky. Take the transfer off the backing, put the sticky side down on the model in the right position and then put a drop of water on it and rub lightly until the paper comes off. Thats if you have the kind of transfers I'm thinking of.
hope this helps
-Daniel
    August 2003
Posted by South Aussie on Saturday, May 22, 2004 4:33 AM
Sounds like the decals have been transferred to the protective sheet somehow, if they have you wont be be able to use them and therefore up for new ones.
Wayne I enjoy getting older, especially when I consider the alternative.
