Putty?
    January 2004
Putty?
Posted by st_gorder on Thursday, May 20, 2004 6:52 PM
Looking at some putty to fill some nasty seams. Have never used it before and have a few questions. Can you apply it with your fingers? Is it safe to do this? Do I need any special tools? Best kind to buy? Help?
Steve
    January 2004
Posted by MusicCity on Thursday, May 20, 2004 8:13 PM
Swanny has a good article on puttying seams on his web site at:
http://www.swannysmodels.com/Seams.html
I use a palette spatula I got at an artist's supply store. I wouldn't recommend using your fingers, nor if you use any of the toluene based putties would I recommend breathing the fumes.
There are several threads about puttying seams in here, and one recommendation I saw but haven't tried is for porcelain sealer. Here is a link to that one:
http://www.finescale.com/fsm/community/forum/topic.asp?TOPIC_ID=19822
I've also heard ot people using auto body filler, and other non-modeling types of filler.
Squadron putty works pretty well, I use it quite a bit. It will adhere to styrene but not to resin. It is also a bit grainy. If you let it dry thoroughly it polishes pretty smooth but if you try and sand it before it's dry it doesn't finish very smooth.
Milliput is a 2-part epoxy putty. I've only used it once and that was just to add some internal support. I don't think it is really suited to seam repair since it is very stiff and won't form into the seams that well.
    January 2004
Posted by st_gorder on Thursday, May 20, 2004 10:44 PM
Misuccity;
Thanks lots.
Steve
Posted by pingtang on Friday, May 21, 2004 9:52 AM
Tamiya putty is not bad but it shrinks a fair bit and will keep shrinking for days but it does sand well. I've never used any of the others though. To apply the stuff I just use a toothpick and I mask either side of the seam to keep it a bit cleaner. I wouldn't suggest using your fingers to apply it, it tends to stick to your skin pretty well.
Gap filling super glue does a good job too. I get a couple of drops out and let it go off slightly, then just apply with a toothpick. You can mix it with tamiya putty and get avery quick drying putty that doesn't shrink much. The only problem is that you have tho work quickly.
hope this helps
-Daniel
Posted by Anonymous on Sunday, May 23, 2004 11:22 PM
Don't go crazy on Squadron Putty. You'll find yourself spending twice the amount of time wet sanding it. Squadron's my last resort
    January 2004
Posted by st_gorder on Tuesday, May 25, 2004 4:24 PM
Thanks mcity, fokkerpilot and pingtang.
Steve
Posted by Anonymous on Thursday, May 27, 2004 1:08 AM
What about Humbrol Model Filler. Does anyone ever use it. I'd like to have your comment if so.
Thanks
Spawney
