Am I the only one who hates resin parts?
Posted by MikeV on Saturday, June 12, 2004 7:40 PM
I spent quite a bit of time trying to get these SOL Industries 1/48 scale AIM-120 AMRAAM missiles built only to have the fins continually break off each time one was even barely bumped. I finally got them all on and started priming them to see how they looked, which was not that great really. Upon inspecting them one fell to the floor and broke most of the fins off again so I put them in the garbage can where they belong. I wish Revell would have used their brain before releasing this F-15E kit so that it would have had some normal styrene ordinance rather than this resin junk. SoapBox [soapbox]
Now I have to build two more since the SOL kit came with six. Angry [:(!]
    January 2004
Posted by MusicCity on Saturday, June 12, 2004 9:18 PM
I haven't done much with resin, two cockpits to be specific, but I have noticed a couple of things about using it:
1) Resin is fragile as egg shells. Look at it wrong it will break. Drop it, it will break. Use too much pressure painting it or drip glue on it too hard, it will break (OK, that one is a lie but it sounded good!).
2) In some cases there is no way to clean up or trim a resin part without breaking it.
3) In some cases, using styrene parts that came with the kit to supplement the resin parts is the only way to remain sane.
4) People who build entire kits out of resin have a much lighter touch than I do and the patience of a saint.
5) Did I mention the stuff breaks easily?
Posted by Anonymous on Sunday, June 13, 2004 7:01 AM
Mike,
I definately feel for you. I built a resin electric generator kit and had a very difficllt time just as you did. It taught me a lesson. Avoid resin like the plague.
Ricchard
Posted by MikeV on Sunday, June 13, 2004 9:46 AM
QUOTE: Originally posted by RSaddlemire
Mike,
Ricchard
I can see how much the reminder of using resin bothers you.
You even spelled your name with two "C's" instead of one. Laugh [(-D]Laugh [(-D]Laugh [(-D]
Posted by rjkplasticmod on Sunday, June 13, 2004 11:35 AM
I like the detail you can get with Resin, especially for cockpit interiors, but it is fragile. For Bomb/Missle fins, it's really not much more than flash thickness in resin. I prefer to use old PE frets and cut fins from the unused border material, which is often close to scale in 1/48. Still a Censored [censored] to glue with CA, but at least they dont snap off if you look at them too hard.
Posted by MikeV on Sunday, June 13, 2004 12:11 PM
Thanks Rick.
I rebuilt them last night and they came out better this time.
The back fins had small tabs sticking out of them that fit into recessed dimples in the missile body. I didn't like that so I went and drilled into the dimpled areas with a #65 drill bit and fit the fins into the holes which made them much stronger. Thumbs Up [tup]
I see that FlightPath makes a 1/48 resin AIM-120 set that does have the photo-etched metal pieces for the fins. It looks even more difficult to build though as it has 90 parts for two missles. [:0] Laugh [(-D]
    June 2004
Posted by clfesmire on Sunday, June 13, 2004 12:22 PM
Many of the kits I build in 1-87 are resin. I get a good one and I love it, a bad one and I've wasted my money. As far as being fragile goes, it all depends on what type of resin the manufacturer uses. I like working with resin because it can be carved and shaped easier than styrene or metal parts if there are imperfections in the castings.
Posted by Anonymous on Sunday, June 13, 2004 10:55 PM
I like the resin stuff that comes out personally. yeah...it's fragile, and I like to break it to keep me on my toes, but the details are second to none most of the time. I'm sure the first wood modelers felt the same way about the first plastic kits to come out. I have thought about doing a whole resin kit, but.......I'm not quite that insane.....yet!!!! LOL
Posted by Anonymous on Monday, June 14, 2004 1:52 AM
The resin I use for my own parts is a bit softer than most of the kits out there. It has a little more flex to it, whick makes it much more resiliant, though it's still more fragile than styrene. The only thing that has ever bothered me about resin kits are the giant casting plugs. It isn't neccessary to mold them that way, though it is certainly easier for the garage shop.
At my old job resin parts were our bread and butter. They're no big deal to me. You really want something to pull your hair out? Try working with the extremely delicate parts made with StereoLithography machines http://computer.howstuffworks.com/stereolith.htm. The epoxy resin used to make those parts, though surprisingly resiliant, are like glass, and the machines leave heavy build lines on the parts which need to be sanded smooth. We had a guy who just couldn't do it. He broke nearly every large part he worked on just from sanding, and several small ones. He got fired within three weeks. Oh yeah, and don't ever drop them. They shatter like glass too. Nothing worse than crawling around on the floor looking for tiny amber shards amidst all the finishing debris and dust on under a table.
    January 2004
Posted by knight667 on Tuesday, June 15, 2004 12:05 PM
I can't stand resin...I hate it so much I pretty much refuse to work with it. But that's just me. Big Smile [:D]
Have you thought about using Hasegawa's weapons sets? Plenty of ordinance there. I think "C" is the one that has most of the air-to-air missiles.
John "The only easy day was yesterday." - US Navy SEALs "Improvise. Adapt. Overcome." - US Marine Corp. "I live each day/Like it's my last/...I never look back" - from "I'm A Rocker" by Judas Priest
Posted by Anonymous on Tuesday, June 15, 2004 12:20 PM
eeeeeeeeeeeeeeeeeeeeeeeeeeee..............
ain't the biggest fan of resin but, some of the cocpit and modification creators sure do some nice stuff.......and since i like chopping and cutting and altering and changing and adding on........aside from photo etch resin is the way to go.........Banged Head [banghead]
i feel for ya Mike........seems like Censored [censored]scratch building is the only way to go if resin is out.......
Posted by MikeV on Tuesday, June 15, 2004 7:40 PM
No, the Hasegawa weapons sets do not have AIM-120's at all.
Next time I build another F-15E I will buy the Revell Pro Modeler version as it comes with AIM-120's. Big Smile [:D]Wink [;)]
Posted by Anonymous on Wednesday, June 16, 2004 3:21 PM
I was looking at a resin cockpit set for gavia's (sp) 1:48 la-7. You could see through the side walls. It's in my wish box there, but will come out because I had no clue that it was so brittle. But the detail on them was something else.
-Jeff
    November 2003
Posted by shrikes on Wednesday, June 16, 2004 5:22 PM
Hmmm... this is kinda discouraging... I was looking around my favorite hobby shop the other day, and saw a resin detail kit for a 1/72 Academy mustang, and then i saw the academy kit was just behind me. If I had the money then, i probably would have gotten it.
This came as quite a shock to me, because in this part of the world, you either have to order the stuff for the right kit (and shell out a lot of money), or be very lucky to find a AM resin detail set and the kit it was made for... You think should still try for this? I have never used resin before... Smile [:)]
Blackadder: This plan's as cunning as a fox that used to be Professor of cunning at Oxford University but has now moved on and is working with the U.N at the high commission of cunning planning
    May 2004
Posted by seanrgb4 on Thursday, June 17, 2004 4:02 PM
used a verlinden set for that revell phantom i was doing , same thing you look at them they break arrgh , then you fit them into the cockpit ,, they dont fit properly double arrrrgh , so i sent them both to bruce , his now put them all together , attach rockets then good bye to ####
Posted by Anonymous on Saturday, June 19, 2004 2:41 PM
gotta agree with musicity but who can resist to the superb molding details they have....?
Posted by Anonymous on Saturday, June 19, 2004 5:52 PM
i hate some resin parts, especially mpm kit resin. i have this one resin kit where the resin is EXACTLY like styrene, even easier to work, its flexable even more than styrene and it's sooooo goood..... yeah. but i hate other resin parts.
Posted by Woody on Saturday, June 19, 2004 6:08 PM
I personaly like resin bits but thin pieces can be a pain. You might concider replacing thin parts with brass shim stock or thin styrene card stock.
" I wish to have no connection with any ship that does not sail fast; for I intend to go in harm's way." --John Paul Jones
    July 2003
Posted by saltydog on Tuesday, June 29, 2004 1:35 PM
aw man, i cant assemble a kit without resin!!! i gotta have. i just did a stang cockpit with a PE set from eduard. the PE set don't cut it in my opinion. however, the resin instrument panels and seatbelts dont look as real as PE belts and panel. thats why i purchase aires cockpits because they have jut the right amount of both.
but, to answer your question mike, i hate some of the characteristics of resin such as having to attach the parts with CA, trying to clean the flash from tiny parts without damaging it, and the general brittleness of it, but i can easily get over it when i see the finished product!! i looks so much better that most kit pits. as for ordinance, i've never assembled a set of resin ordinance, but it seems it would definetly be a pain.
i just assembled a resin and PE pit for a westland whirlwind that that actually came with the kit and it just wasn't well thought out in my opinion. you had to cut out tiny instuments from a resin foot and most of the parts took nearly 5 or so minutes of delicate cutting to loose them from the foot. then, there were 2 control sticks that had to be carved from what looked like a pool of resin!! terrible!! the aires cockpit sets are really simple and look great. later.
Chris The Origins of Murphy's Law: "In the begginning there was nothing, and it exploded."!!! _________ chris
Posted by berny13 on Wednesday, June 30, 2004 10:10 PM
I don't mind resin as long as it is all resin. What I hate is resin/PE combinations. I built an ejection seat that was resin/PE. Trying to get the PE parts, some as small as a gnat's whisker, bonded to the resin part was almost impossible. It kept sticking to the tweezers or you finally get it in position only to watch it fall over. After fighting with it for over an hour I threw it against the wall and pulled out the kit molded plastic seats and went from there. I am in this hobby for fun and relaxation, not frustration.
Berny
 Phormer Phantom Phixer
On the bench
Posted by MikeV on Wednesday, June 30, 2004 10:23 PM
I hear you Bernie. Laugh [(-D]
I kept having the fins fall off when I bumped them but after thinking about it here recently I was wondering if that is because I didn't wash the resin parts in soapy water first. Would that cause CA to not adhere as well?
    July 2003
Posted by saltydog on Thursday, July 8, 2004 4:31 PM
the next trip to the LHS just grab some accelarator!! instant bond that will hold well enough to do the job. i dip the small part in a drop of CA and get a dab on it, i'm holding the part with tweezers by the way, and i'm holding a syringe full of accelarator in the other hand. i touch the part to where i want it and then move in with the acc. add a drop of acc. and it wicks into place similar to a wash and you have an instant bond with no falling over or sticking to the tweezers. the PE becomes magnitized to the tweezers sometimes which is totally aggreviating. later.
    May 2003
Posted by qmiester on Thursday, July 8, 2004 9:22 PM
If you glue or paint resin, you have to wash them (which of course increases the odds of your breaking some of the parts) - the mold release compound seems to be thicker and/or heavier that what is used on styrene kits. I've only built a couple of models with resin AM interiors and wheel wells. Takes a little extra work but I do like the results. For bomb or rocket fins (I tend to model mostly 1/72 WWII aircraft) I keep a couple of sheets of .002 and .005 brass shim stock and some .010 stryene. Anyway, resin cockpits are not near the amount of work that detailing a 1/72 cockpit with stretched sprue and styrene takes.
Just remain calm, continue on and when all else fails use the 16 oz ballpeen on the part. lol
Quincy
Posted by Anonymous on Friday, July 9, 2004 10:38 AM
yep
