Super Glue
    June 2004
Super Glue
Posted by nicevillescott on Thursday, June 24, 2004 7:14 PM
Can you use it to build an entire model, or is that not recommended?
Posted by MikeV on Thursday, June 24, 2004 7:32 PM
You can build most of the model with it alone if you want.
    July 2003
Posted by Foster7155 on Thursday, June 24, 2004 7:33 PM
Sure you can. It's really personal preference. However, on plastic models, solvent glues actually "weld" the plastic together, providing a more solid bond - particularly on large components.
If you ever get into resin kits, they have to be completely assembled using CA glue since solvent glues don't react with the resin.
Robert Foster
Pensacola Modeleers
Posted by rjkplasticmod on Thursday, June 24, 2004 7:36 PM
If your'e building a resin kit, CA ( Super Glue ) or epoxy are the only alternatives. For a regular injection kit, you could use it for the entire build but I wouldn't recommend it. It's very useful for gluing non-plastic parts like Resin or PE to the styrene, but liquid glues like Tenax or Testors will give better results glueing plastic to plastic.
    June 2004
Posted by nicevillescott on Friday, June 25, 2004 1:58 PM
Thanks for the info. I think I'm about light years away from touching a resin kit though.
