help on detailing the cocpit
Posted by Anonymous on Friday, July 9, 2004 10:44 AM
I have looked at hundreds of models before and I built alot of them.But the problem is detailing the cocpit.How does anybody put paint on them little gaguages and nobs? I have wondered about that for a long time. so I am asking how does any pro-modler do it? I have a detail brush and try to do it but never works.can anybody help me?Sad [:(]
Posted by Anonymous on Friday, July 9, 2004 10:21 PM
Simple answer is dry brushing. Here is a link.
http://s96920072.onlinehome.us/tnt1/001-100/TnT087_Drybrushing_Bamford/TnT087.htm
I don't use the larger brush the link shows. I use a very worn 5/0 spotter.
-J
Posted by Anonymous on Saturday, July 10, 2004 1:39 AM
Yeah thats a good link. I airbrush mine then do some weathered aribrush( same color with 10%white added) then I dry brush the details...does it good.
Posted by Anonymous on Saturday, July 10, 2004 8:06 AM
Something I've read about and just tried for myself with good results is to paint the panel all white with a white primer. Once that dried, I used a clear coat. Finally, I used a water based black paint. Then I took a small flat file and lightly sanded the raised portions of the gauges. For the insides, if I couldn't get the flat file to work, I used a fine dental pick to scribe the insides. I was well please with my first attempt and hope to get better with it. I'll seal the entire panel again with a clear coat to prevent the water based paint from scratching off accidentally. HTH's
DonAlien [alien]
Posted by Anonymous on Sunday, July 11, 2004 3:53 AM
I have done the same thing Don has mentioned above. Save one thing.
After you put the water based black paint on you can take a Q-tip and dampen it with Isopropyl Alcohol. Gently rub the gauges with the q-tip to remove the black from the gauges until the white shows through.
This works really well when the black is still a little wet. Just don't put too much pressure on the q-tip or you may take more off than you intend to.
Hope this helps.
Paul
Posted by Anonymous on Tuesday, July 13, 2004 8:27 AM
Paul
Thanks Paul, I'll try that, do you think it would also work with the new micro brushes? I just ordered a bunch and found my old alcohol dispenser bottle from my old electronic days and was trying to think of a way to use it... now I guess I can put alcohol back in.Big Smile [:D]
DonAlien [alien]
Posted by Anonymous on Tuesday, July 13, 2004 2:12 PM
Microbrushes should work just fine. The reason I said the q-tips was you can lay them flat on the surface you are working on and if the paint is wet enough the weight of the q-tip itself will remove just enough to get the white or base coat to show thru.
Good Luck and let us know how it turns out.
Paul
