dropped flaps and askew control surfaces
    June 2003
Posted by grenadierII on Saturday, July 10, 2004 12:33 PM
I am by no means new to the hobby, but I have never had the fortitude to drop the flaps on my kits. I have read about doing it by using a x-acto blade or scriber. Is there another option?
"mmm....forbidden doughnut".
Posted by Anonymous on Saturday, July 10, 2004 12:43 PM
I know some kits have AM flaps availible. I've never used them so I don't know how well they look or fit.
-J
    June 2003
Posted by grenadierII on Saturday, July 10, 2004 12:55 PM
I've seen some of those aftermarket flaps. They look good, but I want to find a way to remove the kit flaps without tearing up the wing or ruining the panel.
    January 2004
Posted by MusicCity on Saturday, July 10, 2004 1:47 PM
Admittedly this doesn't really answer your question, but if you are going for realism, check the photos. Some planes were always parked with the flaps down, i.e. the F4U Corsair, while others were never parked with the flaps down. Most variants of the F4U even had a step cut in the right inboard flap to facilitate entering the cockpit. Later model planes, espially those with leading edge slats, Fowler flaps, etc. nearly always had everything cleaned up when they were parked.
Posted by Anonymous on Saturday, July 10, 2004 2:56 PM
The "trick" is to remove as narrow a line of plastic as you can, if you just want to reposition the kit part. You'll need to thin the trailing edges of the wing, stabilizer, or tail.
Then you need to replicate the part of the control surface that is now showing. Depending on the scale & which control you are moving, you can use strip or sheet styrene or even stretched sprue.
I dropped the flaps on the A-36 in my signature pic. I used the backside of a #11 blade, thinned the trailing edges with files & sandpaper, and used sheet styrene for the new exposed surface.
Hope this helps.
Posted by wayne baker on Wednesday, July 14, 2004 3:44 PM
If you have a razor saw, you can use that also.
 I may get so drunk, I have to crawl home. But dammit, I'll crawl like a Marine.
Posted by rjkplasticmod on Wednesday, July 14, 2004 4:01 PM
I think the scriber is the safest way to remove flaps, but Razor saws & #11 X-Acto blades also work.
    July 2004
  • From: ...Ask the other guy, he's got me zeroed-in...
Posted by gringe88 on Thursday, July 15, 2004 1:20 PM
another way is if you're goin ta use AM flaps, just cut out the flap the easiest way possible for u, then just sand or file off the remaining edges of the flap left on the wing. prepare the wing as suggested by the instructions, and then attach them like the instructions say.
hope it helps---
Matt
====================================== -Matt
Posted by Anonymous on Sunday, July 18, 2004 1:29 PM
I saw a tip on another forum that sewing thread works, so I tried it with impressive results!
Tim Landers
Posted by Anonymous on Sunday, July 18, 2004 8:13 PM
ive always sanded the back to thin the area thin took the back of an exacto knife and scribed out the part.
Posted by F105-Thud on Tuesday, July 20, 2004 3:02 PM
I`ve found the best method of removing flaps and control surfaces is to use a razor saw and an Olfa scribe tool. Worked great for me on my Tamiya 262. Lots of thinning was required, but just remember to measure and test fit more than once, but only cut once.
