Acrylic paints
Acrylic paints
Posted by Anonymous on Thursday, January 2, 2003 5:29 PM
I have been out of hobbing for a little while, & now I am getting back into the hobby. I have started to dabble in the use of acrylic paints. I have heard that distilled water is good to use for a thinning agent. I just can't find any around here, nobody carries it anymore. Does anyone have any suggestions ? Also what is a good test for the right consistancy for an airbrush?
SF340_Driver
Posted by jcarlberg on Thursday, January 2, 2003 9:13 PM
If you check drugstores and grocery stores you usually can find distilled water. If not, then many times isopropyl alcohol will give good results. And if they have clean filtered drinking water, you can de-chlorinate it by letting it sit and breathe for an hour or so. Also each acrylic paint maker has a dedicated thinner, and that often gives the best results.
Posted by naplak on Wednesday, January 8, 2003 12:59 AM
I use Testors thinner for all acrylics... you can oder it from testors on-line and a little goes a long way.
I use about 20-30% thinner, but it depends on your air-brush, the pressure,a nd the finish you want. SO you'll have to experiment some.
http://www.naplak.com/modeling/
www.naplak.com/modeling ... a free site for modelers www.scalehobby.com/forum/index.php ... a nice Modeling Forum
Posted by Anonymous on Wednesday, January 8, 2003 1:23 AM
I like to use a combination of isopropyl and distilled water. Both are inexpensive unlike name brand acrylic thinners.Make sure you get the 99% isopropyl, do not use a lower percentage. Some drugstores keep the 99% behind the counter. Iso also works great for cleaning your equiptment afterwards.
Posted by Anonymous on Wednesday, January 8, 2003 10:19 AM
Regarding consistency I use milk consistency with very good results. I mix 40-60% paint with 60-40% thinner (I use Tamiya for both paint and thinner), you should try other ratios depending on the paints and thinners you use.
    January 2003
Posted by markuz226 on Monday, May 12, 2003 10:10 PM
I just mixed alcohol with ordinary tap (but filtered) water. can I still dechlorinate it after mixing with alcohol?
Posted by John Howling Mouse on Friday, May 16, 2003 4:29 PM
While we're at it, does anyone out there use Testor's Acryl paints? When Tamiya paints (my former favorite) skyrocketted locally in price a few years ago, I made the switch to the then-cheaper Acryl line. They seem to be the strangest paint on the market. While Testor's states the Acryl line is "water washable" and "non-toxic" it also contains "glycol ethers"???? Any chemists here? And, I find that neither water, nor Testor's own Acryl Cleaner nor Thinner really cleans their own paint. The stuff dries too fast, IMHO, even faster than Tamiya's but now I've collected a hobbystore's inventory worth of the stuff. Not so bright on my part, especially with their current pricing trend up here. Anyone else using Acryl paints?
"No, no, no, don't tug on that-----you never know what it might be attached to."
