Rivets from water-filter canisters!
Posted by Anonymous on Wednesday, July 14, 2004 6:25 AM
I can't remember where I read about this technique, but I have found it incredibly
useful for scratchbuilding AFV models, and it could also be useful for adding detail
to kits.
Water filter canisters contain a mixture of tiny styrene spheres (between 2mm and fractions
of a millimetre in size) and charcoal fragments. The spheres make excellent rivet heads for anything
from 1/35 to 1/76 scale!
Cut open a used-up filter canister with scissors or a razor saw, then tip the contents onto some paper towels and leave them to dry (for as long as possible, it needs to be totally dry otherwise the bits stick together), and put them
in a plastic box or jar to store. Tip some of the mixture into a dish, and pick out the plastic spheres with tweezers. You can attach them by applying a tiny drop of glue to the surface of the model, then placing the "rivet" on with tweezers. Since they seem to be made of a styrene-type plastic, they stick easily with ordinary plastic cement.
Posted by Anonymous on Saturday, July 17, 2004 12:59 AM
What kinda water filter canister are you talking about, Like brita filters?
    January 2004
Posted by Ali1kj on Saturday, July 17, 2004 7:03 AM
The HOW to Do is here BTW
http://www.ww2modelmaker.com/articlepub/ISrivtip.htm
Alasdair
Posted by Bones-coa on Wednesday, July 21, 2004 9:19 PM
So what brand filter would us yanks purchase for this?
Dana F On the bench: Tamiya DO335B-2 with LOTS of Aires stuff (On Hold) Trumpeter A-10 with LOTS and LOTS of aftermarket goodies! (On Hold) Tamiya 240ZG (In work)
    June 2004
Posted by ewc2003 on Friday, July 23, 2004 11:41 PM
The Britta water filters here work fine. Just cut the very top section off...there is no bag, and there are a ton of carbon chips in our filters, but millions of tiny styrene beads...
Matt ------------------------------------------------- "The only thing necessary for the triumph of evil is for good men to do nothing." - Edmund Burke
