What are your techniques for making intricate paint masks?
Posted by Anonymous on Monday, July 26, 2004 2:24 PM
As some of you know, I'm working on a Williams Bros. GeeBee-Z. It has a rather intricate black-on-yellow paint scheme that is going to be quite the challenge for me as I've not tackled something of this complexity before.
I sat and thought for quite a while about how I was going to make paint masks for the wings and fuselage. Fortunately, 1:1 three-view drawings were supplied with the kit. I made several photocopies of these in order to cut them up to use as templates for making my paint masks.
But I think I've come up with a pretty cool method to actually make the masks themselves. Tell me if this is something that you've seen or used before.
1) Lay down a rather long sheet of saran wrap
2) Over the saran wrap, lay down several strips of 3m painter's tape, sticky side down
3) Using rubber cement to hold them in place, lay your templates down on top of the 3m tape
4) With a new #11 blade, cut along the edges of the template
5) Peel the templates from the 3m tape
6) Dry fit the paint masks on whatever parts you're masking
7) When you're satisfied with the fit, peel the saran wrap off the back of the 3m tape and apply the masks to your kit
This is good for both pre-designed paint schemes (as the one on the Williams Brothers kit was) or your own designs as well. Freehand works very nicely, and if you need to duplicate your work (i.e. for the other side of the model kit), just flip the newly created paint mask over and run around it with the X-acto.
I can post pictures if you all like.
Posted by rjkplasticmod on Monday, July 26, 2004 6:11 PM
A very interesting technique you have there. The Gee Bee is a pretty complex scheme with the scallops & your approach should work fine. I build mostly WW2 so the camo schemes are not that complex, but I do make my own soft masks for something like the RAF disruptive camo. I have the schemes in full size for both 1/48 & 1/72 scales. Similar to your approach, I transfer the scheme to heavy bond paper, cut the mask from the paper & position it on the model using blue-tac or double sided tape. You want a very sharp edge on your scheme, while I want a slightly soft edge. Your approach sounds great for the effect you are after.
Regards, Rick
Posted by wibhi2 on Monday, July 26, 2004 9:26 PM
wait a minute......why even bother with the plastic wrap (sounds interesting tho). Fit the paper template/mask to the model then lay a piece of tape on some glass and cut away to your hearts content.
You could also get your hands on a roll of low-tak frisket paper (art supply store) and dispence with the paper and tape completely
3d modelling is an option a true mental excercise in frusrtation
    May 2003
Posted by qmiester on Monday, July 26, 2004 9:32 PM
I was going to suggest the tape and the frisket but got beat to it. Would suggest that instead of cutting up the origional kit plans, make copies and use those - that way if you screw up the copies, you'll have a set of replacements.
Quincy
Posted by Anonymous on Monday, July 26, 2004 10:24 PM
Q:
I did use copies.
W:
Frisket paper isn't as cheap, and I find it's edges don't stay down nearly as well as the blue 3m tape. Glass sounds like a good idea though.
Posted by Anonymous on Tuesday, July 27, 2004 1:53 PM
I tried something like that a few years ago, but I found the copy machine slightly enlarged and distorted the original printing. It was a very precise scheme, and that little bit of slop was too much. Maybe the newer copy machines are better.
