Resin parts?
Resin parts?
Posted by garyfo on Tuesday, April 22, 2003 4:11 PM
I'll be workin on my first kit that has resin parts on it.
Do I need special glue for them, or will the regular ol' 'orange testors' tube work?
What sorts of things do I need to be aware of when I'm working with the resin as well. (here I'm thinking I have 3 cats...is the resin toxic?)
Gary
Posted by midnightprowler on Tuesday, April 22, 2003 4:51 PM
Use crazy glue or 5 minute epoxy to glue resin, and if you sand it, wear a mask, resin dust is very irratating.
Lee
Hi, I am Lee, I am a plastiholic.
Co. A, 682 Engineers, Ltchfield, MN, 1980-1986
1 Thessalonians 4:13-18 1 Corinthians 15:51-54
Ask me about Speedway Decals
Posted by seaphoto on Tuesday, April 22, 2003 5:13 PM
Plastic cements will not work at all (solvent types) or very poorly (tube types) on resin parts. Use CA type glues or epoxy as mentioned above. Be sure to wash the parts, as some casters use mold release that will cause poor paint adhesion. Auto Body putties stick well to resin if you need to fill a gap. Cut off as much excess casting sprue with a saw (if there is an excess). Wet sanding will keep the dust down and make the cats happier - or at least as happy as cats get. Resin is very soft and can be sanded or cut very quickly and with little effort.
If the part is to be attached to a plastic model, it never hurts to pin it with brass rod instead of relying solely on the holdin power of the glue.
Prime the parts with a quality primer, such as Floquil, then overcoat with the paint system of your choice.
Have fun!
Kurt
Kurt Greiner
Interested in large scale, radio control warships? http://www.warshipmodelsunderway.com
Posted by Anonymous on Tuesday, April 22, 2003 6:17 PM
try a detail set like a cockpit set first, then move to other things like resin cockpit canopys, resin updates/corrections, then scratchbuild your own! <-- jk
    January 2003
Posted by shermanfreak on Tuesday, April 22, 2003 6:34 PM
I always use CA glues for working with resin and have had great results with it. Use one that's a slower curing otherwise once they're stuck, they're good and stuck. There are some concerns with resin dusts and health. Just keep the little furballs out of the room while you're working with resin and clean up good behind yourself and you should have many unhappy years ahead of you with them. LOL
Posted by garyfo on Wednesday, April 23, 2003 10:57 AM
Thanks guys! That's exactly the info I was looking for!
Gary
Posted by Anonymous on Wednesday, April 23, 2003 11:47 AM
Gary, here's a bit more info that some people may not know. Resin dust can be toxic, especially if burnt, so don't drop it into the ashtray, it can produce phosgene gas, highly naughty. As above, I'd go for the wet sanding, using plenty of water, and superglue or epoxy to fix it in place.
P.S. Cat whiskers can make great whip aerials!
