Reverse Vacu-Forming
Posted by Anonymous on Monday, August 9, 2004 8:26 PM
Before i waste styrene, has anyone vacuum formed the inside of an aircraft before? And if so, how successful was it?
I know it works best when vacu-forming convex surfaces, but i'm curious if it's equally successful on concave surfaces as well?
    February 2004
Posted by Tailspinturtle on Tuesday, August 10, 2004 3:43 AM
The detail is actually a little crisper on the inside (the side next to the shape you vacuform over) than it is on the outside. Almost all vacuform kit makers use a mold with depressions in it so the exterior has detail like panel lines and the gap between fixed and moveable surfaces - it is a harder mold to make than one with a lump or lumps on it. The lump would provide better (but not resin quality) detail on an interior part that is concave.
Posted by Anonymous on Tuesday, August 10, 2004 7:53 AM
Thanks for the input. The aircraft i'm working on is in such large scale that if i go through with this, i'll be using 2 large sheets of styrene to accomplish what i'd like to do. The plus side i would imagine is that the aircraft has windows down the side which 'should' allow the plastic to pull down a lot better.
I've formed normal items with detail before, but never tried forming a 'bowl'. Guess it'll be trial and error.
Thanks again!
