Cutting fuselage for detail kit
Posted by Anonymous on Friday, August 13, 2004 10:44 AM
I just bought an Aries resin detail kit for a P-47D and was wondering how I cut out the area for the engine. Do I use a Dremel tool or is that overkill?
Where do I find the paint color for the detail kit? The Aries instrucctions dont have paint colors for the parts.
    August 2003
Posted by tweety1 on Friday, August 13, 2004 11:35 PM
A Dremel would do the job, depending on the scale.
You might want to use a scribe if you have one, or even your hobby knife blade.
I recently bought a PE saw kit, and after using it for the first time I have no idea how I ever got by without it.
As for paint scheme, research is the best thing you can do.
Check out other modellers builds, and search the net for pics.
My 2 cents [2c]
--Sean-- If you are driving at the speed of light and you turn on the headlights, what happens???
    September 2003
Posted by glweeks on Saturday, August 14, 2004 1:46 AM
You might try using an Xacto saw or a jewlers saw. The dremel could work too, just don't get too close to the finished panel line, sand your way into last few millimeters. As far as color goes check the reference forum, the aircraft forum, the library, go to an airshow, look in the engines (lots of biplanes use Pratt & Whitney engines, the size and number of cylinders may be different but the colors are about the same) take pictures.
Welcome to another level of insanity.... oops I mean modeling.
G.L.
Seimper Fi "65"
    January 2004
Posted by MusicCity on Saturday, August 14, 2004 6:38 AM
Very, very carefully!! As the old carpenter's adage goes, "Measure twice, Cut once." In other words, make certain that you know what you are removing before you cut it off because it is hard to put back.
Areas to be cut out like that are always different. If you only need to remove a small amount of styrene, a file or sanding sticks might work. If there is a lot, a Dremel or razor saw might be better suited to get you close, and then switch to a file and finally sanding sticks or sandpaper.
As mentioned by the others, don't try and cut down to the finished line. Go slowly and carefully when you start getting close and dry fit frequently. Going too far is a bad thing!
Posted by Anonymous on Saturday, August 14, 2004 6:44 AM
......without reservation, hesitation or doubt.........Bow [bow].........absolutely heed these words ! !
Posted by Anonymous on Thursday, December 9, 2004 3:22 PM
You could use the trick of silk thread, it cuts clean creates nearly no heat and you can go around corners without having the usual problems.
