New way of dealing with raised panel lines?????
    August 2003
Posted by tweety1 on Tuesday, August 17, 2004 4:24 AM
Last night I was playing around with my Mig 29, and had a brain wave about making the raised panel lines stand out.
I loaded the ab with some enamel paint and traced the raised lines.
Got home from work tonight and gave the body a spray with some acrylic paints.
After about an hour, I grabbed a Qtip, dipped it in some acrylic thinner, and LIGHTLY went over the raised panel lines.
Allowing for the fact I was only testing this theory, it turned out pretty well.
With a bit more patience, and a lighter touch, I reckon this will make rescribing panels only necessary when I absolutely have to.
I'm curious aqs to whether anyone else has played around with this idea, and if so how did theirs turn out?
I have a Japanese Mavis covered in rivets I've been putting off because of the scribing thing, and this may just work for that too.
--Sean-- If you are driving at the speed of light and you turn on the headlights, what happens???
    August 2004
Posted by jdavidb on Tuesday, August 17, 2004 6:08 AM
I guess I'm a cheater on raised panel lines. I use watercolor pencils or the chalk pastel pencils I just discovered. I usually overcoat them with clear lacquer, so it turns out durable.
Your idea can also be done by lightly rubbing through the overcoat with the back of an x-acto knife. That'll give a little more control than a q-tip offers. Especially with enamel on the bottom, and acrylic over the enamel lines, the chance of grinding through the enamel isn't too bad.
    March 2004
Posted by bstrump on Tuesday, August 17, 2004 9:39 PM
I use a pencil. You need one that's fairly hard. Rather than use the point, I run the side lightly over the panel line to highlight it. Then seal it.
Posted by Anonymous on Thursday, December 9, 2004 7:21 PM
I just found a great article by swanny's models about how to convert (scribed) raised lines to recessed panel lines. Here it is. I think I'll give it a try it solves a lot of problem later on when you need to finish the model. http://www.swannysmodels.com/Scribing.html
Steve
