Sanding marks
    May 2004
Sanding marks
Posted by KINGTHAD on Friday, September 10, 2004 8:27 AM
No matter how hard I try I always get sanding marks. How do you guy deal with this problem?
Thad
    January 2004
Posted by MusicCity on Friday, September 10, 2004 8:41 AM
Increasingly fine sandpaper. Start out coarse and work your way down to very fine grit. Each step will remove some of the sanding marks from the previous step. You can just go from coarse to very fine, but the very fine grits don't cut much so it takes forever.
Posted by Anonymous on Friday, September 10, 2004 8:42 AM
......and if i might add......use'em wet.......it'll help carry the sanding residue away in the water and keep said residue from clogging your sandpaper.....and/or gouging furrows in your subject........
    May 2004
Posted by KINGTHAD on Friday, September 10, 2004 10:33 AM
Musiccity, That is the current way I am doing it, I was hopeing for a different way maybe.
Cirikili, I have not tried to wet sanding, I will give it a try
Thanks
Thad
    July 2003
Posted by KJ200 on Friday, September 10, 2004 11:03 AM
Thanks
Thad
What grade of paper are you using?
I generally sand wet with 600 grade wet'n'dry, then finish off with a nail buffing stick, working from roughest to finest. This usually leaves a polished surface.
Karl
Posted by Anonymous on Friday, September 10, 2004 11:46 AM
How about use some plastic polish??? I get rid off some fine sanding marks with Tamiya polishing compound and water......
    May 2004
Posted by KINGTHAD on Friday, September 10, 2004 12:29 PM
Thanks for the info feli250, I will have to try that
Thad
Posted by Woody on Friday, September 10, 2004 10:37 PM
I use the sanding methods as stated above but I finish with very fine synthetic steel wool.
" I wish to have no connection with any ship that does not sail fast; for I intend to go in harm's way." --John Paul Jones
