detailing the red door edges on US Navy aircraft
Posted by mass tactical on Sunday, September 12, 2004 12:08 PM
Hello group. Need your help on this one. In order to make my US Navy aircraft look as real as possible I would like to learn best techinques on getting those pesky door edges red on both 1/48th and 1/72nd scale models. I have tried painting but my hand is not steady enough to do a good job. Thanks for helpBig Smile [:D]Big Smile [:D]
Mike M
Posted by Anonymous on Sunday, September 12, 2004 10:52 PM
Get one of those flat-tipped (not pointed) model paint pen markers made by Tamiya or Gunze Sangyo. The stiff, flat tip is ideal for the red edgings on gear bay doors, and you can do it in one pass. I've used it on my U.S. Navy planes and they came out okay. You'll have to watch out though that you do not press too much on the tip since that increases the paint flow. A light touch is all it takes. Hope this helps.
Cheers,
onyan
Posted by Anonymous on Monday, September 13, 2004 2:52 AM
I've used strips of red decals to detail the landing gear doors of my USN aircraft with success. I use a pair of dividers to measure the length of strip needed, cut the decal, and with a new no. 11 X-Acto blade and a steel straight edge, trim it to the correct width. Then with a 5-0 brush I apply a bead of Future on the edge of the gear door. Once the decal has been moistened and is ready to slide off the backing, I slip it onto the edge of the door usually with the tip of a moistened 5-0 brush or a needle chucked into a X-Acto knife handle. To strengthen the decal and bond it to the gear door, I apply another bead of Future once it has set up; usually an hour or so. I usually have to trim up the decal, both length and width, with a new X-Acto blade once the overlay of Future is dry.
The process is tedious and necessitates the use of a magnifying lamp/lens, but the end result is worth it. Hope this helps.
Dick McC
    March 2004
Posted by bstrump on Monday, September 13, 2004 4:01 AM
I myself use an old #11 knife blade. Just dip the tip in red and run along the edge of the door. Not very high-tech but it works.
Cheers
Bert
Posted by mass tactical on Monday, September 13, 2004 7:54 AM
Thanks for all the help. I'll try all suggestions to see which one works best for me. Thanks again!Big Smile [:D]Big Smile [:D]
Mike M
    October 2003
Posted by f-4phantom on Tuesday, September 14, 2004 6:15 PM
Best thing I've found for this is a red Sharpie. There are different sizes you can use. Two or three coats will cover.
Dean
Posted by Lufbery on Friday, September 17, 2004 3:55 PM
I used a regular fine point red pen with good results on my 1/72 scale F-4 Phantom. :D
Regards,
-Drew
Build what you like; like what you build.
Posted by armorman on Thursday, September 23, 2004 10:45 PM
I think i do it the hard way... I dab a little white out on that edge, usually with a bit of stretched sprue and then i use the Tamiya red pen Onyan mentioned. It makes the red really stand out and then i give it and the interior of the panel, flap, etc a little wash to sim oil.
Next Up: 1/35 Tamiya Merkava 1/48 Tamiya King Tiger 1/35 Dragon M1A1 AIM
