which is finer?
which is finer?
Posted by Anonymous on Tuesday, September 14, 2004 8:45 AM
hi
just wondering if some one could tell me which will give a finer finish.. toothpaste or tamiya polishing compound?
and has anyone applied tamiya polishing compund with and electrice toothbrush?
thanks
Posted by JCon on Tuesday, September 14, 2004 9:46 PM
Now that is an interesting question that I never gave any thought to. Apparently no one else has either as I see lots of people have read this and not written anything. I have used toothpaste but not the Tamiya polishing compound so I am not sure... the toothpaste did the trick for me on clear plastic parts. Hopefully someone with more expertise in this area will help us out with your question...Tongue [:P]
Happy Modeling, Joe Favorite Quote: It's what you learn after you know it all that counts!
Posted by ajlafleche on Wednesday, September 15, 2004 2:52 PM
I don't usually do cars so polishing isn't high on my list but I picked up a set of polishing pads in the car section of one of my LHS's. This goes up to 15,000 grit. You can polish out clear parts with this even better than the original. Works as well dry as wet.
Posted by Anonymous on Wednesday, September 15, 2004 10:55 PM
Sign - Ditto [#ditto]
I accidentally sprayed a canopy black . I used these and then dipped in future, better than new.
Posted by Anonymous on Thursday, September 16, 2004 9:34 AM
im looking for some of those pads but have had no lluck yet....
Posted by JCon on Thursday, September 16, 2004 6:17 PM
I haven't seen them either, are they available online somewhere?
Posted by pingtang on Friday, September 17, 2004 11:27 PM
Tamiya has a new line of polishing compounds. course, fine and finish I think they're called. The finish stuff is probably the best way to polish a high gloss finish. Thye aren't cheap though.
I think the polishing pads you're talking about are micromesh. It should be available somewhere on the net. Just do a search.
hope this helps.
-Daniel
Posted by Anonymous on Friday, September 17, 2004 11:40 PM
yeah u can get them at micromark.com, its just that i wanna get em locally.....and if i start ordering from micromark i got a feeling that my credit card will get maxed out real fast ;) thewres just so much cool stuff there!!
Posted by Anonymous on Thursday, December 9, 2004 3:05 PM
Use meguires mirror glaze for plastics, it comes in different grades and is perfect for canopies and clear parts!!
Posted by Tinker on Tuesday, December 14, 2004 2:58 AM
A paste mixture made with cornstarch and water is also a good polishing compound. Back in the 60's and 70's many of the custom car painters ( full sized cars ) used that for final buffing to get rid of swirls.
" 'Polls' are surveys of uninformed people who think it's possible to get the answer wrong." ...Ann Coulter
Posted by Anonymous on Tuesday, December 14, 2004 12:35 PM
I do not use either.. What i do is polish it out after each coat of clear from 3200 grit to 12000 grit polishing cloths and then after the last one ( i do this 3 times and after each time going through the grits i clear coat again) i then use Clear one more time and i shoot 3 coats for the final coat and that make it look like a toy car.
http://public.fotki.com/shawCustom/shaw_show_cars_for_2004/100_6049.html
Pluse look through all the folders and you will see my F/W Roadster that one is on the first stage of it not even close to being done when its done you will see the motor in the fire wall like a mirrer
Posted by Anonymous on Wednesday, December 15, 2004 10:25 PM
tominator,
You can find the polishing cloths at Hobbyco.
http://www.hobbyco.com.au/product/show_item.php?plu=ALC301
