what has the maskol done to my beautiful paint!
Posted by Anonymous on Saturday, September 25, 2004 10:21 AM
i have just masked off a large area of acrylic paint with maskol, sprayed the unmasked bit, jumped for joy, then removed to maskol to find that the cursed maskol has done something to the paint. its a different color from the unmaskol-ed bits. what has happend ? its only a shade darker, will it go away if i spray flat clear?
    July 2004
Posted by tho9900 on Saturday, September 25, 2004 10:42 AM
wierd... I've never had that happen... the paint was cured real good? that's the only thing I can think of... is it a new bottle of maskol?
    August 2003
Posted by tweety1 on Saturday, September 25, 2004 6:39 PM
Maskol has a tendency to do that, especially with acrylics.
I had it happen to me once, and I resprayed the area, rather than try and find a way around.
Have never used Maskol on acrylics again.
To date, I have never found a liquid mask that didn't affect acrylic paints.
Sorry I cant be of more help.
--Sean-- If you are driving at the speed of light and you turn on the headlights, what happens???
    July 2003
Posted by madmike on Saturday, September 25, 2004 10:37 PM
Maskol has amomonia as an ingredient I believe. Ammonia and acrylics do not get along so well :(
At art stores you should be able to pick up a true acrylic friendly masking agent and I believe that Microscale's, Micromask is good as well.
I share your annoyance, it has happened to me!
cheers
"I do not feel obliged to believe that the same God who has endowed us with sense, reason, and intellect has intended us to forgo their use." - Galileo Galilei
Posted by Anonymous on Sunday, September 26, 2004 2:30 AM
darn. i use only acrylics, so this means my maskol is useless, unless im spraying on top of laquer rattle can paint. gah. i forgot that amonia isnt good friends with acrylics...... thanks, ill see if i can find some friendlier masking material
    August 2003
Posted by tweety1 on Sunday, September 26, 2004 4:20 AM
Micromask has never worked on any acrylics I've used.
Used it on a Mi24 once, and had to respray the tailboom cause the Micromask latched onto the acrylic and wouldn't let go.
Seeing as it's water clean up, makes sense really.
Posted by Anonymous on Sunday, September 26, 2004 7:31 AM
dang, looks like blu-tack is going to be the next best thing..........
    July 2004
Posted by tho9900 on Sunday, September 26, 2004 8:05 AM
I use this stuff called Master Mask from Hobbico... it works pretty good overall and works fine on acrylics as well... I got mine at Hobby Lobby... (sorry I know that last bit wont help you Reggie)
you might be able to order it from hobbico.com
Posted by Anonymous on Sunday, September 26, 2004 9:05 PM
Yup, Reg, Mike hit the nail on the head: ammonia is a no-no to water-based acrylics, just like Windex which contains the stuff. I use Microscale Micromask which is also water-soluble but seems to be benign on acrylics, provided that they are thoroughly-dried/cured and that you don't handbrush water-based paints (or spray on a heavy wet coat) over it. Sometimes Micromask is difficult to take off, though, as tweety1 said, specially if it's laid on too thinly. In those cases I sometimes dab a piece of sticky tape onto the masked areas and try to lift the Micromask off gently, but most of the time I use a water-soaked cotton bud to dissolve a portion of the mask. Once there's an opening, I peel the mask from there.
Sorry I can't be of much help to your problem, bro. You can try spraying flat clear over it and hope it evens out the shade, you'll lose nothing anyway. By the way, did you apply Future over your acrylic paint before masking?
Cheers,
onyan
Posted by Anonymous on Sunday, September 26, 2004 11:34 PM
I also have the same problem, but I am using regular masking tape.
the glue from the masking tape left on the body, and I have tried using compound still can't be cleaned.
Posted by Anonymous on Monday, September 27, 2004 6:56 PM
to get ride of the tape glue take another piece of tape and stick it on it then pull up it should lift up the ressidue
Posted by Anonymous on Monday, September 27, 2004 10:31 PM
thanks for the advice
