Scribing panel lines
Posted by Anonymous on Friday, October 8, 2004 9:31 AM
Hey there.
Does anybody have an advise on how to scribe pane lines around the fuselages?? So far straight lines are not a problem but how do you scribe panel line in a circumference??
Thanks
Saul
    July 2004
Posted by tho9900 on Friday, October 8, 2004 10:24 AM
QUOTE: Originally posted by Saul
Hey there.
Thanks
Saul
this should help you: http://www.swannysmodels.com/Scribing.html
a how-to for scribing which should answer any questions andmore! if you still have questions feel free to ask!!!
Posted by Anonymous on Friday, October 8, 2004 12:11 PM
Great site!! thank you for the tip.
Saul
    July 2003
Posted by KJ200 on Thursday, October 14, 2004 3:27 AM
I'd not looked at that bit of Swanny's site before.
Glad I have now.
Karl
    July 2013
Posted by modelmaker66 on Thursday, February 18, 2016 3:56 PM
i use dymo tape, the stuff for the old labeling guns. I cut a suitable length, stick it down in place and use it as a guide to gently run against, very  gently.
    January 2014
Posted by Silver on Thursday, February 25, 2016 2:28 PM
Get the UMM scribe tool and watch the video on the internet .Its the best scriber in the world.Winners of nationals use this tool.John Vojteck
Posted by Texgunner on Friday, February 26, 2016 10:46 AM
Dymo tape works well.  I also use short sections of vacuum cleaner belt, cut to various widths and lengths.
Gary
"All you mugs need to get busy building, and post pics!"
    February 2016
Posted by SilenceDeuxgood on Thursday, June 9, 2016 10:11 AM
Typically, i will plus up the thickness of Frogtape by placing a few strips together, then trim the edges with a new #11 blade, ensuring a crisp edge, then i will place the tape around the fuselage where the line is to be scribed, and VERY very gently scribe the line with multiple passes using a Trumpeter Panel Line Scriber against the crisp edge of the tape. Once the panel line is where i want it to be, i remove the tape, run a quick sanding stick over the line to ensure the edges are flat to the surrounding area, and Voila... done.
Hope this helps
OTB: 1/32 P-47D #228382, 1/24 AMG GT3 "Battlefield 1",
"Semper en Hostes"
"Ne Desit Virtus"
    August 2013
Posted by Putsie on Thursday, June 23, 2016 3:11 PM
I guys !
I use thin brass....often left from a photo-etched part tree....binds around things....hold it with fingers or tape the ends.......works well for me......
Have fun !
    August 2013
Posted by Jay Jay on Friday, June 24, 2016 8:25 AM
Silver, on your recommendation i just bought the UMM scribing tool . Yes
The thing works  amazingly well ,with practice, and there's very little build up of the edges of the panel lines to clean up. Cool how it curls up the scribed plastic out of groves it makes. Instead of plowing a line it actually cuts or planes the panel lines. All my other scribers are hunting for an alternate use now .
Many thanks for the tip Mate.
