lead foil
    September 2004
lead foil
Posted by mm23t on Monday, October 11, 2004 11:14 PM
Where do you buy lead foil? What is the best way to prepare for painting? Any thoughts?Big Smile [:D]
Medals are not "Won", they are "Earned".
Mike..
Posted by Anonymous on Tuesday, October 12, 2004 12:22 AM
I wouldn't know where to buy it. I've used the foil from around the cork of wine bottles, or even the high quality chocolate coins (like the ones they make in the Netherlands, they use a thick foil, not at all like regular tin foil). Some people prepare the foil for painting by etching it with a weak acid (like vinegar). I've only used the foil a couple of times for seatbelts. I didn't prepare the foil for painting, but had no adhesion problems.
Al
Posted by Anonymous on Tuesday, October 12, 2004 7:49 AM
mm23t,
I get mine at http://www.mcmaster.com/ Look up lead foil tape. Or Item #76315A61, or catalog page #3201. You'll have to soak the adheasive off the back with Acetone or lacquer thinner, but it's not a big deal. Keep in mind that this is dangerous stuff. No eating or drinking or smoking while you are using it and clean up your self and your work area after you use it. Don't use power sanders (Dremels) on it without some sort of particle mask. As long as you're careful, it's a wonderful modelling medium.
Paint it like you would any other metal surface.
    September 2004
Posted by mm23t on Tuesday, October 12, 2004 10:18 AM
Thank you for the information. It's just what I was looking for.
Mike..
Posted by Anonymous on Tuesday, October 12, 2004 2:40 PM
I've used empty toothpaste tubes....works like a charm
    July 2003
Posted by madmike on Friday, October 15, 2004 6:56 AM
If you go to the dentist, ask if you can have the little lead patches that come with the X-ray film. They are perfect for small tarpaulins or to be cut up for seatbelts/harnesses.
I got a bag with enough lead floil to last me for ever or until my stash is gone :)
cheers
"I do not feel obliged to believe that the same God who has endowed us with sense, reason, and intellect has intended us to forgo their use." - Galileo Galilei
Posted by Anonymous on Friday, October 15, 2004 11:40 AM
Pewter foil....... embossing section of the Craft store.......
Posted by kielers on Monday, October 18, 2004 8:48 AM
Great Models Web Store has lead foil also, if you buy any of your stuff online.
"To stand upon ramparts and die for our principles is heroic, but to sally forth to battle and win for our principles is something more than heroic." -- Franklin Delano Roosevelt. "Never in the field of human conflict was so much owed by so many to so few." -- Winston Churchill
