Question about glue
Question about glue
Posted by Anonymous on Thursday, October 14, 2004 10:24 PM
Hey Guys, I have a Question I am having problems getting plastic and my model cement to hold to the metal photo etched parts I would appreciate any help you could render.
Posted by Anonymous on Thursday, October 14, 2004 10:30 PM
Plastic cement will not work on metal, resin or vinyl parts, as it works by softening the plastic and than hardening it again after the softened plastic from both gluejoint sides have become "mixed".
Use a 2-part epoxy glue or CA/Super-glue.
HTH.
Posted by pingtang on Thursday, October 14, 2004 11:56 PM
Plastic cement works by "welding" two parts together. It'll slightly melt the plastic and join the two (just like real welding). So it definitely won't work on metal photo-etch parts or resin, because it is designed to weld plastics.
To attach PE parts try using either CA (super) glue, an epoxy or a white glue (even wood glue will work). For a strong join, I use CA. But if I will have to move the part around, to get it in position, I'll use white glue.
hope this helps.
-Daniel
Posted by Anonymous on Saturday, October 16, 2004 12:24 AM
Thanks for the Help
