Painting issues.....
Posted by Anonymous on Monday, October 18, 2004 10:24 PM
I was wondering how i could get over that orange peel texture on this mustang that i am working on- its the first car that i have painted and that little thing is peeving me a lot.
Any ideas? Question [?]
Posted by Anonymous on Tuesday, October 19, 2004 2:31 AM
sand it smooth with some 400-800 grit sandpaper. the orange peel is caused by a overly thick coat of paint, so if you lay down thinner coats you wont have this problem. having said that, sometimes no matter how thin you lay the paint on, it still orange peels.
    January 2004
Posted by MusicCity on Tuesday, October 19, 2004 6:43 AM
Orange Peel is normally caused by the paint partially drying before it hits the surface of the model. This can usually be avoided by spraying closer to the surface and / or at a lower pressure. If you are using rattle cans you obviously can't adjust the pressure and you have to be careful getting closer to the surafece because of the volume of paint that they put out.
Posted by Anonymous on Saturday, October 23, 2004 12:23 AM
That means you thin not enough you should have more solution. It should be look like the milk from the box. And I not sand I touch with 1500 - 2000 grit with water and after painted let it dry by try to cover it with box or other to avoid dust.
