A new way (cheap) to make custom exhausts
    April 2004
Posted by crockett on Monday, November 15, 2004 9:14 AM
I had a brainstorm the other day. While building the Hasegawa 1/32nd Mustang I realized that the kit exhausts were neither to scale or correct. So, I had to get inventive. The offerings from Moskit are great but too expensive and, as luck would have it, out of stock when I needed them. After much experimentation, I came up with something that is OUTSTANDING!
The answer to my dilemma was Shrink tubing. You know, the rubber tubing they sell at the hardware store to insulate wire? It reacts to heat (applied with a hairdryer). It cuts great, can be shaped and sized to just about any configuration, and costs a few bucks for a package of six. It comes in an assortment of sizes all the way down to 1/4 inch. The quarter inch stuff can be reduced to a very small ID by the application of heat.
Check out the application here in my pic. As I experiment more, the applications of this tubing will cover my armor work as well.
Steve
    September 2003
Posted by maffen on Monday, November 15, 2004 11:14 AM
that's great Steve Wink [;)] been using it for years now ,used it for sleeves for towingcables in armourbuilds Big Smile [:D]
Posted by Anonymous on Monday, November 15, 2004 2:10 PM
I have found quiet a few uses for heat shrink tubing in my model builds.
    April 2004
Posted by crockett on Monday, November 15, 2004 4:25 PM
Luc,
I should have known you would have thought of this already!
Posted by Anonymous on Monday, November 15, 2004 4:29 PM
They also make good "foam paddings" on roll-cages for Rally cars, etc.
    September 2004
Posted by mm23t on Tuesday, November 16, 2004 9:22 PM
This is why I enjoy this forum so much. You learn something new everyday.
Thanks guys!Thumbs Up [tup]Thumbs Up [tup]Thumbs Up [tup]
Medals are not "Won", they are "Earned".
Mike..
Posted by Anonymous on Friday, November 19, 2004 10:52 AM
how do you use it ? can u give us more details ? i am intimately familliar with heat shrink tubing - i use it all the time for my R/C cars wiring
    April 2004
Posted by crockett on Friday, November 19, 2004 1:34 PM
Reggie-
Hey Man it's easy! To form an exhaust stack, let say with a compound curve, just cut a piece of wire (any kind will do) and shape the wire the way you want it. Then cut your tubing to size, insert it over the shaped wire and apply the heat! When the diameter looks right pull out the wire and your done. For more control, just roll the tube on a warm surface, (I use a metal lamp shade). For the Mustang, I depicted unshrouded exhausts, I cut the tube to size, angle cut one end of each tube, and used a small dowel to heat the tube to size. Use CA to attach.
Good luck,
Steve
Posted by Anonymous on Saturday, November 20, 2004 6:44 AM
i get it ! Smile [:)] thanks for that tip
Posted by Anonymous on Monday, November 29, 2004 9:04 PM
this is just brainstorming and i mean to get try one of these when the need arises but: how bout soda can aluminum? that seems maleable enough to make exhaust (in a bigger scale of course you'd go blind doing it in smaller scales...) also, sprue...cut it, and boar out a hole in the center, u might not get very thin edges but i have used it successfully. I use mostly things from around the house when i cant find a part or money is tight, improvise!! i have used: soda can aluminum, aluminum foil, paper, transparencies...
