Producing weathered wrought iron
Posted by Bones-coa on Saturday, November 20, 2004 6:32 PM
Modelers, my wife is tring to paint some resin-cast crosses to look like wrought iron that is extreamly weathered. It may have been a mistake, but I employed my resources to her to try and find a way to reproduce this look using my model paints. Can anyone give me some direction on how to produce this? I was hoping I could start with some MM metalizers and go from there.
Thanks in advance.
Dana F On the bench: Tamiya DO335B-2 with LOTS of Aires stuff (On Hold) Trumpeter A-10 with LOTS and LOTS of aftermarket goodies! (On Hold) Tamiya 240ZG (In work)
    July 2004
Posted by tho9900 on Sunday, November 21, 2004 10:17 AM
ok assuming the wrought iron was originally black (which it is around here), there are several levels of weathering.
new = flat black paint with a hint of light grey or white added
been outside for a bit = "new paint above" with a very faint light grey wash for your average wrought iron finish
add a light dry brushing of white and then rust to create a neglected look.
when drybrushing I would concentrate the white on detail areas as these would fade faster (dunno why, there is a wrought iron place near my house and the stuff they put out front always has whiter detail) also a light white wash that was allowed to settle in the detail would do good... faint drybrushing of white over the rest... pick out some rust with a tiny brush...
that should do it!
if it is not black I would start with a dark aluminum with a diluted dark wash on the detail and go from there like above...
    May 2003
Posted by qmiester on Sunday, November 21, 2004 10:59 AM
Dana,
I'm not sure that I would go with metallics as most wrought iron I've seen is flat black. It seems to go from a very deep flat black to a very , very dark gray with rust spots here and there. (at least that's what the wrought iron on both my neighbors and my front porches look like. Before we repainted them). I would airbrush a base coat of the darkest black I could find and then drybrush several overall layers of lighter blacks/dark grays over it, finishing with areas of rust.
Quincy
