Oils
Oils
Posted by Anonymous on Wednesday, November 24, 2004 1:36 PM
Hi there,
I was just wondering on what to do. I just bought oil's and want to do a wash. What are my options to use for thinning it, or better yet, I guess I need to know how to do it. I looked in the forum's but didn't find exactly what I was looking for. Also, what else can I use them for?
Thanks
Jeff
    July 2003
Posted by Foster7155 on Wednesday, November 24, 2004 2:10 PM
If they are standard oils (regular linseed oil based), they can be thinned with turpintine, turpinoid (less agressive), and some generic paint "thinners" including mineral spirits. If they are the new line of oils with a water-soluble oil, then water will thin them.
In either case, I would coat your model with Future first and let it cure. This will seal your paint job, improve the way the wash flows, and allow for easier removal in case of errors. Once the wash is on the model the way you want, allow it to dry completely seal it with Dull Coat, and press on.
What else are they good for? Oils are great for figure painting because of the way they can be blended. Many award-winning figure modelers swear by using oils.
Hope this helps...
Robert Foster
Pensacola Modeleers
Posted by djmodels1999 on Wednesday, November 24, 2004 3:14 PM
Also great for drybrushing; as they take longer to dry, you have more control over the blending.
    April 2004
Posted by pmm736 on Wednesday, November 24, 2004 3:18 PM
I use Grumbacher oils, which are thinned with mineral spirits
Posted by Anonymous on Wednesday, November 24, 2004 11:51 PM
I use Grumbacher oils thinned with odorless Mineral Spirits, which I bought at my local hardware store.
Glenn
Posted by Anonymous on Thursday, November 25, 2004 12:11 PM
Thanks for the input guys, but what is a good thinning ratio?, And do I just usr spirits to clean up. Last question :) should I use separate brushes for them? Thanks and have a good turkey day!
    July 2003
Posted by Foster7155 on Thursday, November 25, 2004 12:52 PM
I knew you'd ask that...
I don't use oils for washes, so I can only give you an idea based on the MM enamels that I use.
I'll fill up a standard MM bottle about 3/4 full of thinner. Then I'll dip a small paint brush into whatever color I'm using (usually black, dark brown, or burnt umber) and then clean the brush off in the bottle. I'll usaully do that 3 times. So your talking maybe 97% thinner to 3% (just a wild guess).
The point is, until you've practiced and know exactly what you are looking for, an extremely light wash is better than a heavy one because you can always add more.
Someone who uses oils for washes will have some better advice...
Robert Foster
Pensacola Modeleers
    April 2004
Posted by pmm736 on Thursday, November 25, 2004 1:30 PM
You thin and clean up with the mineral spirits. I'm very new to this method and still learning myself but the advice that I've seen is to add a very small amount of paint to the spirits, just enough to basically make the spirits dirty. You can then adjust the ratios to your liking by adding a little more at a time until you achieve the look your going for. Hopes this helps, Pete
Posted by Anonymous on Saturday, November 27, 2004 12:03 PM
Last question,
Can you airbrush oils?
Posted by djmodels1999 on Sunday, November 28, 2004 2:06 AM
By the time they are diluted to the right consistency, I'm sure you'd have little pigments left... Oils are no good to cover a surface with a uniform, even layer of paint. They are too transluscent for that. Oils are normally used over base coats of enamels or acrylics (the latter being better to avoid problems!), and give effects of shadowing and highlighting.
Posted by waikong on Thursday, December 2, 2004 9:02 AM
I've used oil a few times and go along with all the advise already given. I would just add that it takes a long time to dry (the more paint the longer it takes). Overnight is the minimum you have to wait - even if it looks dry 3-4 hours later. I've waited up to 2-3 days for oil paint to be sufficiently dry before working on the model again.
Posted by Anonymous on Thursday, December 2, 2004 3:54 PM
do you wait overnight before wiping the excess oils off, leaving only the oils in the panel lines? I have always done it within minutes but maybe I am doing it wrong?
Posted by djmodels1999 on Thursday, December 2, 2004 4:22 PM
I don't. I remove the excess and blend straight away.
