Gasoline stains and Rust
    September 2003
Posted by KevinCollins on Thursday, November 25, 2004 9:52 PM
HiSmile [:)],
Could someone explain to me a good way to simulate gasoline stains on tanks?....I was going to use a thinned enamel wash but my base coat is acrylic and I though I would eat through it with the enamel.....would IQuestion [?]
Also, I would like to make some rust on tanks too....two ways, plain rusted out panels and runny, streaky looking rusted panels.....(I guess the rust streaks could be done like the gas stain could be done...but I'm not 100% sure....)
Any help would be much appreciated.
Thanks and Happy Thanksgiving to all!
Kevin
Pray for Surf! Proud sailor (USNR) of IBU 21...NCW Group2
Posted by Anonymous on Thursday, November 25, 2004 9:59 PM
Here is what I do on Motorbike Models, I use Clear Yellow (maybe add a tiny bit of clear orange) to stain the crankcase where normally petrol drops of the fuel tap(common on older bikes).
Rust there are many methods from buying products like rustall to actually using rust and so on.
    April 2004
Posted by pmm736 on Thursday, November 25, 2004 11:45 PM
A coat of Future on top of the base coat will solve the problem of the wash reacting with it.
    June 2003
Posted by Duke Maddog on Friday, November 26, 2004 6:53 AM
For rust, get a small Brillo steel wool pad, used for cleaning in the kitchen. Soak it in Water until it rusts. For newer rust, pull it early when the rust is orange, for older rust, wait til it's more brown. Once the rust is the color you like, crush the rusted pad into powder. Voila! Your very own rust!
To apply over surfaces, you can brush the powder straight on, then seal it with a dullcoat. For 'running' rust, mix some of your rust powder with a mix of 50-50 water and white (Elmer's) glue. Dip a brush into this, and then place it on the model where you want it to run and let it run down the sides. Once it's dry, you can seal it again with a coat of dullcoat.
Hope this Helps! Wink [;)]
    September 2003
Posted by KevinCollins on Tuesday, November 30, 2004 7:28 AM
Thanks for the replys....they all sound great!
