Squadron / Signal Modellers Putty?
    August 2004
Posted by four-star on Saturday, November 27, 2004 9:56 AM
What has been people's experience with this putty - is it any good? Thanks
    October 2003
Posted by rebelreenactor on Saturday, November 27, 2004 4:54 PM
Well, the green putty dries fast so it does speed up time when building. I still favor the tamiya putty though.
John
    December 2003
Posted by wooverstone8 on Saturday, November 27, 2004 8:11 PM
I use Squadron putty and it works fine for me.
    January 2004
Posted by knight667 on Tuesday, November 30, 2004 10:01 AM
I use Squadron white and thin it with denatured alcohol. I keep it in a small 1/2 oz. bottle and use that for gap filling...works like a charm. Check out this thread:
http://www.finescale.com/fsm/community/forum/topic.asp?TOPIC_ID=25180
John "The only easy day was yesterday." - US Navy SEALs "Improvise. Adapt. Overcome." - US Marine Corp. "I live each day/Like it's my last/...I never look back" - from "I'm A Rocker" by Judas Priest
    August 2004
Posted by four-star on Thursday, December 2, 2004 7:47 AM
Thanks, that's very helpfullSmile [:)]
    July 2003
Posted by zokissima on Thursday, December 2, 2004 8:31 AM
I've just recently started using their white putty, the one that comes in a tube, and it's worked very nicely for filling gaps.
    September 2004
Posted by mm23t on Thursday, December 2, 2004 6:32 PM
I use the Squadron green putty and have always had good results.
Medals are not "Won", they are "Earned".
Mike..
Posted by Anonymous on Tuesday, December 14, 2004 1:27 PM
I use the green, and also use the red car body putty... the Bondo is a lot less expensive than the modelling putty, and seems to work as well. However, I am going to try using the denatured alcohol to thin some of the green, and some of the red, and christmas up a test kit or two
    April 2004
Posted by pmm736 on Tuesday, December 14, 2004 4:05 PM
I've been using the green and it works Ok, but can be a little agressive and eats at the plastic if you get it all over. There was a thread a few weeks ago about thinning it with alcohol, which is supposed to help with this problem, plus give a longer working time, but I haven't tried it yet.
    July 2004
Posted by tho9900 on Tuesday, December 14, 2004 7:33 PM
I've used both green and white... recently all I've had is a tube of green because I havent been to the shop but it works good in all cases for me...
I thin mine with alcohol usually.. but recently started thinning it with Tamiya Acrylic thinner with better results so I am sticking with that... stays fluid longer than with alcohol, slight longer time till set, but dries in about the same amount of time... (I always buy the big bottle of Tamiya thinner so it's not an issue)
Posted by Anonymous on Monday, February 21, 2005 2:32 PM
Sorry to revive this thread, but I discovered it in a search. I thin the Squadron Green Putty with nail polish remover, and that works fine for me.
Of course, SGP has toluene in it, so always ventilate the room extensively before using it, and don't spend too much time breathing it.
    January 2005
Posted by jinithith2 on Monday, February 21, 2005 4:39 PM
I just got this putty and I used it on the M1A1 Abrams tank back side where a huge gap was present and it worked like magic.
I was a litle scared about the "don't turn on heaters or any other fires while fumes are in the air" thing but it's only the smell, and the heater proved to be safe while opperating.
Posted by Anonymous on Monday, February 21, 2005 7:43 PM
Swanny has an exclent article on Squadron Putty on his website:
http://www.swannysmodels.com/
I have used this method with great results. It's under the "Tools and Tips" section.
Posted by Anonymous on Monday, February 21, 2005 8:24 PM
I use Squadron green putty and bondo red touch up putty. I thin both with lacquer thinner (denatured alchol when I have it too). IMO Bondo is easier to sand it doesn't harden up like Squadron does (it hardens up like granite). So it really depends on what needs to be filled. Big gap = squadron. Small gap or hole = Bondo.
    January 2005
Posted by jcheung5150 on Sunday, February 27, 2005 10:13 PM
I use the green putty, but haven't tried thinning it with alcohol. I've got to give that a try.
You definetely want to ensure proper ventilation when using the green!Dead [xx(]
Jimmy Photobucket
