Washing Parts
Washing Parts
Posted by genj53john on Friday, May 16, 2003 7:43 PM
How crazy is this idea? I hate washing parts even though I know it's absolutely necessary. I had the idea of washing in a dishwasher. I'd build a holder out of window screening and place the parts in it . The holder would keep parts from disapearing in case the break off. Dishwasher detergent should work great at decreasing and all parts, including the tiny ones would get completely cleaned. I'd take them out before the drying cycle. How crazy is this? Anybody ever try this?
John
    January 2003
Posted by leemitcheltree on Friday, May 16, 2003 8:50 PM
I'd give it a go, except for the fact that most dishwashers are a cold-water fill, and have a heater to heat the water to probably around the same temp that your home hot water heater produces. The reason for the heater in the dishwasher is twofold - it helps sterilize the dishes and also helps dry them afterwards.
I'd hate to see the fuselage and wings of a 1/48 scale Catalina after they've been in the dishwasher - can you say "curvy"??
Some dishwashers are a hot-water fill (like mine), and pull water straight out of your hot water heater. If you can't put your hands in the water because of the temperature, it's too hot for styrene.
But good luck anyway.
I'll stick to hand washing my plastic in warm water.
Cheers!
LeeTree
Cheers, LeeTree
Remember, Safety Fast!!!
