Concrete Airfield pan
    January 2003
Posted by ADleitch on Wednesday, May 21, 2003 5:05 AM
Hi Guys, looking to make a couple of concrete airfield pans to display my completed kits on. My question, can anyone remember where the sizes of the concrete slabs can be found? I remember reading a how to in Finescale and for the life of me can't find it again. What I need is the approx sizes in different scales i.e 1/24, 1/32 and 1/48.
Thanks everyone
Its Better to Burn out than to Fade Away!!!
Posted by cmtaylor on Wednesday, May 21, 2003 2:42 PM
What I did, was just rule 1" squares on the surface.
They seem to look ok for 1/72 to 1/72
Have a look at
http://cmtaylor.members.beeb.net/Century21%20Models.htm
The Spearhead, Arrowhead, MT68 all use the same piece of MDF as a base and the slabs look ok for both the scales
Gentlemen! You can't fight in here; this is the WAR ROOM!
Posted by Anonymous on Monday, May 26, 2003 2:40 AM
Hey leitch,
There was an article in the Fine Scale 20th Anniversary Issue, titled, "Modeling Roads and Runways" on pg. 90 by Ed Gilbert. There's a box at the bottom of the first page of the article giving the maximum dimensions for concrete slabs in the most common aircraft scales from 1/24 right on down to 1/144. Hope this helps. If you can't find this issue, let me know and I'll run off a copy or scan it and send it to you.
- Eric
Posted by Anonymous on Monday, May 26, 2003 10:43 AM
The Airfield that I work on has two sizes, approx 8x8 feet & 10x8 feet, I'll leave you to do the maths!
