Micro-Sol/Set
    January 2003
Micro-Sol/Set
Posted by Gumiflex on Monday, January 17, 2005 1:56 PM
Can anyone tell me when/how to use Micro-Sol/Set; are this two the same or is there a difference. Should I use one before others or one is just as good. I also plan to use a Future before I apply decals. Working on my first model.Big Smile [:D]Big Smile [:D]Big Smile [:D]
Thanks
    July 2004
Posted by tho9900 on Monday, January 17, 2005 2:27 PM
They are two different things, Micro-set is used to place the decal first.. you paint it on the body then once the decal is down good you paint a little on top of the decal. It softens the decal and helps it settle down into the panel lines and such better. Also helps to eliminate silvering (tiny bubbles trapped under the decal)
Micro-sol on the other hand is the muscle of the two. Unruly decals, lots of contours on a spot where a decal goes is where this one comes into play. It's more aggressive and will REALLY soften a decal. When you first put it on it wrinkles the decal up and gets you really scared! Not to worry, by the time it dries it will suck itself down flat onto the model and be pulled into every nook and cranny that plastic has!
That said you don't ALWAYS need Micro sol. I've never had it happen but I have heard stories of it ruining decals etc... usually I only use it when I need to. The decals may be a little thick, they just don't wanna set themselves into the grooves etc... I always push the decal with micro set down with a damp paper towel first, and let it finish setting before making the decision to use the Micro sol...
They have directions on the bottles that are pretty self explanatory. The one part where it says "DONT TOUCH THE DECAL AFTER USING MICROSOL" Is a good one Disapprove [V] I didn't listen the first time I tried them... you gotta wait for them to dry. (I got scared because it wrinkled up so much and was trying to dab it down like with the Microset)
    January 2003
Posted by Gumiflex on Monday, January 17, 2005 3:49 PM
Cool thanks I'm looking to try this out.
    July 2004
Posted by tho9900 on Monday, January 17, 2005 4:34 PM
It really works too! Makes em lay down NICE ad flat... all the panel lines visible through it... make sure you use future or gloss coat on the model first to give a smooth flat finish for the decal. Afterwards coat the model and decals in future or the like again to protect them and if it needs it then dull coat it. Dull coat has a tendency to wrinkle decals bad in my experience... Future stops this from happening!
Posted by Swanny on Monday, January 17, 2005 6:29 PM
Micro-Set and Micro-Sol can cause a white, cloudy effect on Future. If this happens do not worry and do not try to wipe off. Just let decals dry completely then apply more Future and the white will go away.
    January 2003
Posted by Gumiflex on Tuesday, January 18, 2005 8:20 AM
Thank you very much; Swanny thanks for a great site where I did most of my reading. Soon I finish, I will post pic's of my first completed model, so I can get as much advice for future work
Gumiflex
