- Member since
July 2003
Posted by saltydog
on Saturday, January 22, 2005 5:54 PM
i've never tried acrylic washes before jaysun, but here is my process for an oil wash. when i get the paint on the subject like i want it, and it cures thouroughly, i apply a couple of coats of thinned Future(found on most cleaning isles), which does 2 things, acts as a barrier between the paint job and the harsh mineral spirits and artist's oils wash, and it enhances the wash's ability to flow around the base of small details and run the creases of tiny recessed panel lines efficiently. when the future dries over night, i have a 6 bowl plastic pallete that i use for mixing up my wash. i fill one of the small containers with mineral spirits, then extract a drop of black and a drop of white pigment. i mix a dark grey concoction that is very thin and load my brush (a #3 testors detail brush most of the time), and touch it to the panel lines and at the base of details and capillary action does the rest. then, i let it sit for about 45 minutes to an hour and go back and remove the excess with a scrap of dry T-shirt material. on stubborn areas, i dip the scrap of T-shirt in some mineral spirits and carefully remove the stubborn spots. what ever type of paint you pick, whether it be acrylic or enamel base, i'd apply the coat of future first, its mandatory in my opinion. later.
Chris
The Origins of Murphy's Law:
"In the begginning there was nothing, and it exploded."!!!
_________
chris
