Q Regarding Marrying Painted Part on Painted Part
    May 2003
Posted by Snacko on Wednesday, May 28, 2003 4:57 PM
This might be a bit obvious to some of you, but I was curious how you handle marrying of painted parts (i.e. attaching a painted bomb on a painted aircraft weapon store. CA?
Thanks,
- Snacko
Posted by Anonymous on Wednesday, May 28, 2003 6:25 PM
I scrape the paint from where the parts will join, and add Testor's model cement. Unlike CA, it actually slightly liquifies the are it's applied, "welding" the two parts together. MUCH better than CA if you ask me!
Posted by berny13 on Wednesday, May 28, 2003 6:44 PM
I drill small holes in the bomb and CA small brass wire in the hole. I also drill the same dia hole in the pylon/MER/TER and insert the brass wire into the pre drilled hole and secure with CA. Bombs do not mount flush with pylons/MER's/TER's. They have a gap when attatch to them. They are then held stable by sway braces and the mounting lugs hold them to the pylon. On missiles I scrape the paint off of the missile and launcher where they will be mounted.
Berny
 Phormer Phantom Phixer
On the bench
Posted by Anonymous on Wednesday, May 28, 2003 7:29 PM
The two methods mentioned will work well. I must admit that I often 'cheat' and just join the two straight away with CA. I always regret it later because the part usually falls off and sometimes takes a chip of paint with it too. You think I'd learn...
Scrape some paint away and do it right.
M.
    December 2012
Posted by FreedomEagle1953 on Wednesday, May 28, 2003 8:24 PM
Sometimes I use small wires, such as berny13 described above ... and sometimes I use the scrape and glue method that TenchiMuyo81 described above ... it just depends on the situation and the parts involved.
As mkish described ... there is just no shortcut ... as much as we all would like to find one ... it just isn't there. Wink [;)]
FreedomEagle1953
Chicago, IL area
"keep on building 'em ... but don't glue your fingers together"
    January 2003
Posted by leemitcheltree on Friday, May 30, 2003 5:43 AM
Snacko,
You've been the recipient of some very good advice here - I'm in touch with the problems Murray Kish talked about. Wish I had a buck for every time I'd knocked a chip of paint off a model because I'd attached a part with CA............The message here is DON'T knock anything off your model that's been attached with CA. Doh!!
I often do what Berny does - drill two holes - one in the part and another corresponding hole in whatever it attaches to, and use wire of some sort. This can also have advantages like adding immense structural rigidity (eg. using stainless steel wire ) to a part or sub assembly - can be a real bonus.
Cheers,
LeeTree
Cheers, LeeTree
Remember, Safety Fast!!!
