Is there a "tacky" CA?
Posted by Anonymous on Thursday, May 29, 2003 7:12 AM
I use CyanoAcrylate (CA) adhesive to marry small parts to other small parts or large ones. I am using a brand called Zap-a-Gap
which, as its name implies, is primarily used for gap filling. Consequently, it is very difficult to put parts together with this brand of CA if there is no pre-existing support for the part(s). It often requires 3 hands, and the parts are often too small for a jig.
Does anyone know of a CA that is inherently tacky, or that sets up quickly enough that it can be used for these small but cruical jobs?
Thanks in advance.
Posted by midnightprowler on Thursday, May 29, 2003 7:24 AM
The thinner types of superglue usually set up right after contact.
Lee
Hi, I am Lee, I am a plastiholic.
Co. A, 682 Engineers, Ltchfield, MN, 1980-1986
1 Thessalonians 4:13-18 1 Corinthians 15:51-54
Ask me about Speedway Decals
Posted by Anonymous on Thursday, May 29, 2003 9:51 AM
And model cement(especially Testors' Non-Toxic) never hurts...
Posted by Anonymous on Thursday, May 29, 2003 9:53 AM
Try using G-S Hypo Cement. It remains tacky for several minutes to several hours, depending on the quanitity used.
I use it for many parts that need fussy positioning. It will glue anything to anything and dries crystal clear.
See page 14 of the March 2003 FSM under News & Products. I get mine from Micro-Mark. Try it, you'll like it.Wink [;)]
Pete
Posted by Anonymous on Thursday, May 29, 2003 11:19 AM
Something else you could try is 5-minute epoxy. It is a two part glue that you mix up and it sets in, as the name implies, about 5 minutes. I use that a lot and I really like it. It really works well for me.
Ray
    January 2003
Posted by shermanfreak on Thursday, May 29, 2003 6:32 PM
Like Lee said, the thinner CA Glue sets up a lot faster. One problem that I have had is that the CA glues I have purchased do have a shelf life on them. If the glue is too old it does not set up properly and requires quite a bit more time.
Posted by Anonymous on Thursday, May 29, 2003 7:45 PM
I use the Black CA(with rubber in it I think). It seems to have a little more working time and "tackiness" if you will. Also try keeping your CA in the fridge, it will extend the life. I've had a bottle in there for two years and it still works fine.
Posted by Anonymous on Friday, May 30, 2003 7:17 PM
Pete,
Regarding the G-S Hypo cement... I found some at Michael's. Haven't used it yet, but it might be another source for other readers who are interested.
Murray
