Wash?
Wash?
Posted by Anonymous on Wednesday, February 16, 2005 5:44 PM
Hi guys, this question may be a little dumb, but hey, I need to know how to perform a wash. I know what it dose but was wondering if someone can tell me how to do it, or any links on how.
Thanks agian!Smile [:)]
    January 2004
Posted by MusicCity on Friday, February 18, 2005 7:26 AM
There was a page here a while back that djmodels wrote that was very good. Not sure where it is now though. Best link I know of is on Swanny's page at:
http://www.swannysmodels.com/Weathering.html
Posted by Anonymous on Sunday, February 20, 2005 3:28 AM
Here's a link to a video , Brett explains how he does it , go to the web site and then click on Mixing an Oil Wash and Applying it to Panel Lines
http://www.scaleworkshop.com/workshop/video9bg_1.htm
cheers mike..
    July 2003
Posted by madmike on Sunday, February 20, 2005 4:40 AM
I used to use oil washes but have moved over to the sludge wash method, as featured in a FSM a couple of years ago.
This is a much easier method of creating a wash and what is more, it is easier to remove if all goes wrong.
Use;
5 parts water
2 parts paint colour for wash
3 parts dishwashing liquid
Mix these together but do not shake (for obvious reasons) and apply over the glossed model surface. Leave to dry for 20 minutes and using a moistened cloth, cotton buds and/or micro brushes to remove the excess wash. This will leave a nicely defined panel line or the wash in nooks and crannies.
The key ingredient is the dishwashing detergent which retards drying time of the wash mix. Avoid using black (unless really necessary) as it is too stark a colour which will leave your model looking like a patchwork quilt.
I am a big beleiever in scale effect!!
cheers
"I do not feel obliged to believe that the same God who has endowed us with sense, reason, and intellect has intended us to forgo their use." - Galileo Galilei
Posted by Anonymous on Sunday, February 20, 2005 9:06 AM
thanks
    October 2003
Posted by rebelreenactor on Sunday, February 20, 2005 9:48 PM
you can use acrylics or oils. I have found oils to be my favorite. The acrylic just seems to wipe away, and enamle, well, just doesnt wipe away! And make sure if you use oils, that your model is sprayed with acrylics, and if your wash is acrylic, make sure the model is sprayed with enamles. Kind of confusing but you'll get the hang of it. Just takes some practice.
John
    July 2003
Posted by Dwight Ta-ala on Monday, February 21, 2005 1:05 AM
Not to confuse you but you CAN use an acrylic wash over an acrylic painted model. I have been doing it and I am getting good results. Just make sure that your base paint has cured properly before applying the wash.
